Old 06-13-2012, 12:26 PM   #1
Don Whitmore
Question Data Recorder Shows 300 rpm 'droop' After Car Launches???
The data recorder is showing a significant rpm 'droop' (300 rpm - 400 rpm) after the car launches (converter flash)...sort of like a 'camel hump' in the run trace.
The car is a 350 ci SS/JA weighing about 3100 lb. The 60 ft times are good for this type car but wondering if they can be improved if the 'droop' is reduced???
I've noticed the Comp cars don't seem to have this issue, so is it something we're doing or just a characteristic of a Super Stock car???
What can be done to reduce or eliminate the 'droop?' Converter swap? Gearing? You just gotta live with it???
Don Whitmore is offline   Reply With Quote
Old 06-13-2012, 12:28 PM   #2
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Data Recorder Shows 300 rpm 'droop' After Car Launches??
That is the converter loading. It is normal to see that in a car like yours.
KRatcliff is offline   Reply With Quote
Old 06-13-2012, 02:10 PM   #3
BlueOval Ralph
Banned
Getting the fuel curve right will help that!
BlueOval Ralph is offline   Reply With Quote
Old 06-13-2012, 02:45 PM   #4
Ed Wright
Ed Wright's Avatar
Mine shows a couple hundred if it turns the tires a little. Dead hooks don't show it.
Ed Wright 4156 SS/JA
Old 06-14-2012, 09:10 AM   #5
Don Whitmore
All...thanks for the input.
@KRatcliff....what is different that the Comp cars don't see to have the 'droop?'
@BlueOval Ralph...would you go leaner / richer in this area? I forgot to mention it is a fuel injected combo.
Thanks for the help!!
Old 06-14-2012, 09:32 AM   #6
KRatcliff
I cannot answer the question on the Comp cars due to zero experience with them. I can only surmise that the ones you may have seen may be leaving at a significantly higher RPM, the converter may be smaller (ie 7"), and the engine isn't pulled down as much or at all when the converter fully engages.
I have looked at the graphs of many fuel injected stockers and super stockers. Every one of them had the same hump. Even our super stocker with a carb combo has a hump. Most were 2 step cars, but a few were foot brake stockers.
Any tuning that you do for this event is basically behind a curtain and you are not exactly sure what the A/F ratios are due to the action of the 2 step. I have a certain pattern of attack for that event, but that is just for my stuff and I have a lot to learn before I come close to getting these tunes right.
Listen to the others with more experience than me on this. I was just giving you my experience.
Old 06-14-2012, 10:24 AM   #7
Aaron Keown
Aaron Keown's Avatar
IMHO you don't see it is much in comp simply because of the nature of the beast, which is light, lighter, and lightest. The lighter cars with higher H.P. are naturally not going to be as susceptible to theese things.
But you should deffinately believe these guys are pointing you in the right direction, but in all honesty there are hundreds of things that if not exactly the right pieces or setup correctly that can cause this. I am assuming you are running an LT-1 in either a camaro or firebird from you info (and please correct me if I am wrong and that is not the case) and I have a little bit of experience with those engines and what you are talking about can make or break the way the car performs. Just for example, one of my best customers Jeff Dona was able to go a 1.18 sixty foot at bella rose. Now given, he is in I and you are J but I am guessing pretty close to the same basic combo, now I am not you so I don't know what you consider a "good" sixty foot time, but in my humble opinion I think Jeff's car is one of the best real super stockers off the line that I have ever seen.
Aaron Keown is offline   Reply With Quote
Old 06-14-2012, 11:16 AM   #8
FED 387
Liked 333 Times in 180 Posts
listen to Keowen if its who I am thinking it is he has built some fast stuff--Comp cars will/might/could have either a tiny flat line or a VERY small droop when the car first leaves the line usually its a rapid upward spike or you hope it is---- A Comp engine regardless of size is making at least 2.6 HP per CU IN and then the really good ones make all the way up to almost 3 HP per CU IN.possibly more!!! The starting line RPM 's ,( gearing , car weight etc.factored in) that they are leaving at too are such that the phenomonen(RPM drop) you are seeing is so small or does not even exist.
I think it would be unwise to try to compare a Super Stock engine such as yours with the graphs from a Comp engine based solely on the tremendous performance differential here... My suggestion would be to find and talk to a similiarly classed car owner/driver for their perspective on this... Also if you have a data recorder you should be talking to the manufacturer for his input on what you are seeing. They are constantly talking to racers so they might be able to figure out a bit what it is you need too. FED387
Old 06-14-2012, 12:38 PM   #9
BlueOval Ralph
Banned
A little richer at peak torque if EFI give it a little pump shot
Old 06-14-2012, 01:48 PM   #10
Ed Wright
Ed Wright's Avatar
Mine used to do it when it was too rich "down there". It was simply pulling the engine down. Now only if it turns the tires. 1.3X 60's there's a hump, 1.2X 60's, no hump.
