#81 | |
Liked 31 Times in 19 Posts
Ya, I've been trying to ignore your latest addition. Man I can't even fiqure out what it is never mind what it came off of. My best quess is a distributor, but it's gotta be old & there's no cam for the points, so ?????? Tag, yur it anyone else liteweight |
#82 |
Liked 333 Times in 180 Posts
49-53 ford flathead front mount distributor???
#83 |
V8 or 6?
50/50 shot at gettin' it right. Better than Vegas!!! |
#84 |
Liked 595 Times in 136 Posts
Neither?
That's a great shot as I've never seen anything even close to it before. Not much I recognized there until I realized the condenser was mounted externally - and it's big! Its mounting bolt would be where the electrical lead snapped on. I suspect the cam lobes might be hidden from view underneath the bracket that locates the center shaft. I'm not sure that I can see the end of the contact block, so if it's underneath that bracket my theory makes sense. And since it appears the part mounts solidly with two bolts, the threaded bolt at 12 o'clock must be to set the duration. Am I getting warm? I think it's definitely an electrical timing device, but not necessarily ignition. Does this go with an early FI system? |
#85 |
Liked 12 Times in 12 Posts
#86 |
Obviously 6 cyl distribution device, just don't know application
liteweight |
#87 |
#88 |
Liked 25 Times in 16 Posts
This is an odd head. I took the photos of it at the Miller Reunion in Milwaukee last year. So it is probably some sort of Indy car head or something like it. I don't know what it fits, but thought I'd throw it out to see if anyone ever saw one. I'm thinking it looks like it fits a Ford V8, or maybe an inline four?
Mopar 2 Ya! |
#89 |
James, that almost looks like one of those mid sixties Indy car engines that had the exhaust pipes that exited from the top of the motor and out the back down the center of the car...I'll try to dig up a photo of one, but I'm still unsure of the type of engine it was, as most were overhead cams.
#90 |
Guess what type of block this was...
