Old 04-26-2013, 08:55 AM   #21
FED 387
Liked 336 Times in 183 Posts
Exclamation Re: enclosed trailer with 15" tires?
JOE- amen on the luck 16 or keep it at home not worth the hassle of tire fsilures and damage to the trailer let alone its just plain dangerous to others on the highways---FED387
Old 06-04-2013, 01:32 PM   #22
4speedracer
Liked 10 Times in 6 Posts
Default Re: enclosed trailer with 15" tires?
where is a good source to get replacement 16" wheel and tire to replace 15" wheel/tire st225/75/15 range e, 6 lug axles on 24' enclosed? thanks jamie
4speedracer is offline   Reply With Quote
Old 06-05-2013, 12:27 PM   #23
bigsixman
Liked 2 Times in 2 Posts
Tredit, they have several locations around the country and their prices are fair. I purchased my two matching spares there for my new trailer back in 2010.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
Old 06-06-2013, 02:21 PM   #24
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
I found some E rated 225-75-15's trailer tires last year. I didn't even know they existed until I saw them.
Best investment yet for my trailer.
I love the way the tires stand straight up....none of that bow-out at the bottom like a radial.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-11-2013, 09:45 AM   #25
ss wannabee
Liked 7 Times in 7 Posts
Aubrey, I like your "home-brew" approach...wish I was half as handy as you are!
Just be CAREFUL!
Wondering...on your trailer..if tires are bias-ply...and the load rating?
How much pressure in them....also your normal towing speed?
ss wannabee is offline   Reply With Quote
Old 07-11-2013, 10:16 AM   #26
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
well, SS, I'm not very good at making money, or managing things, but I can design stuff.
Not really "home brew". More like "logical, purpose-built"
Tires are 205 70 14 radials. 44 PSI max, which I run at about 40. I believe they have a load capacity of 1400 pounds each. Weight on the 4 of them, depending on what is on the trailer, varies between 4000 - 4700 pounds.
Normal towing speed on the highway, is 65-75 MPH.
This unit has been trouble free since 1992.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 07-13-2013, 06:50 PM   #27
ss wannabee
Hey....it ain't fancy...but it works! Not bad!
Old 07-13-2013, 07:35 PM   #28
Aubrey N Bruneau
A lot better than the belly button, fit-all trailers that you buy !
naah, it aint fancy
ID:	20007   Click image for larger version
ID:	20008   Click image for larger version
Old 07-14-2013, 07:19 AM   #29
ss wannabee
Nice!!! My open trailer's not a fit-all....built in a metal-fab shop...ages ago...bed
height OVER 12"....7:00 x15 old-school bias truck tires....axles not offset to the rear
a bit...as they should have been...
A real "white-knuckler" roller-coaster ride everytime...towed with a 1/2-ton Suburban!
Hopefully to be phased-out soon....
BTW....are you shooting for some 10.90's later this years?
Old 07-14-2013, 12:19 PM   #30
Aubrey N Bruneau
Just got got my new clutch from Advanced. Pick up the block in a couple days.
We'll see. My "adjusted" cam profile, HOPEFULLY allows the intake valve train to be in control. If I do manage to make a fast pass or two, I doubt that it would be "official", because to my knowledge, there's only one more available Stock / Super Stock race out west here this year... and it's next weekend in Mission. Can't make that one.
BTW, my old contraption is definitely not a roller coaster ride ! In fact, with the loaded trailer, my truck is way better to drive. Running through that highway on the east side of Golden BC, is something that I look forward to !
