Old 01-18-2014, 02:50 AM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Update E-F/SA Bird Build...
Good deal! I'm going to show this to my partner...he's a big Pontiac fan from way back.
Rich Taylor
I/SA - 321
Old 01-18-2014, 11:10 AM   #12
brent flynn
brent flynn's Avatar
Awesome! I dig your Camaro...hoping to run into you, not it(hehe) at a divisional this year...Maybe Bowling Green or Indy...
Old 02-11-2014, 07:43 PM   #13
brent flynn
Update... Pan and front cover on...cam in @ 104.5... Heads are done, staying in the house until i put them on... it was -16* today... I have junk heads on it, to keep cylinders clean and rust free... Next is rockers and pushrods...and then we can prime it! Dont know if INdy in April is a possibility... Too much $ and not enough time... Im thinkin that Joliet in June is a better , more attainable goal... unless i fall into a boat load of $... No sense in rushing it...
Old 02-12-2014, 12:01 AM   #14
FED 387
Liked 333 Times in 180 Posts
what r u using the silver block drivers side lower just above the pan for???
Old 02-12-2014, 07:15 AM   #15
brent flynn
The alternator bracket attaches to it... I turn the alt upside down...Smog belt for '85 olds v6..
Old 02-12-2014, 12:45 PM   #16
Nice! I see a niche market here..
Old 02-12-2014, 12:49 PM   #17
Doug Domm
Liked 84 Times in 21 Posts
Just what I was thinking. I could likely use a couple of those myself.
Doug Domm is offline   Reply With Quote
Old 02-12-2014, 07:15 PM   #18
brent flynn
Thanks! It works well...doesnt give alot of room behind the Alt, but ive never had a problem... My '62 has same setup on it... and i have a few running around out there, as well... I have a few alum blocks in the cabinet...
Old 02-25-2014, 08:01 AM   #19
brent flynn
Got the new heads on it, last weekend... I figured out what pushrods i needed, and should have them tomorrow... Once valvetrain is set, i can prime it, and its ready to install... Intake is not bolted on yet, as valley pan isnt either. Gettin closer! Converter is at ATi... should get it back anytime
Old 02-25-2014, 09:56 AM   #20
HandOverFist
Sneaking up on it Brent. I need to post you up a pic of my partner's '64 tri-power GTO if we ever roll it out of the back shop sometime.
Rich Taylor
I/SA - 321
