Old 02-25-2014, 06:18 PM   #51
rpmrcn7616
Default Re: '67 Camaro E/SA redo
what stall did you go with on the converter
rpmrcn7616 is offline   Reply With Quote
Old 02-25-2014, 08:55 PM   #52
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Thomas Arnett sent the convertor in to be re-worked...I assume he provided the spec's for our car. I know his family run several similar cars.
Rich Taylor
I/SA - 321
Old 02-27-2014, 02:32 AM   #53
HandOverFist
Finally broke down and bought a quality generator after all these years. All I can say is wow...only 44 pounds and whisper quiet.
Blasted my old t(rusty) trailer Sunday afternoon and sprayed it completely with bedliner coating...no more rusting and painting for me. I should have done this years ago. All new bearings/races/seals installed along with new led lights.
Rich Taylor
I/SA - 321
Old 02-27-2014, 07:33 AM   #54
brent flynn
brent flynn's Avatar
Looks good! Good luck at test and tune... So were you able to use the powerglide/4spd crossmember? I have a 4spd crossmember, so if i ever go with a 200, i will be able to put it right in...
Seeing your trailer kinda makes me wish i didnt have an enclosed(i bought last June)...i miss the thumbs up, when people go by me on the highway...
Old 03-01-2014, 10:40 PM   #55
HandOverFist
Default Bowling Green PukeFest
Well, things went well until I ventured on the track today. Spent some time on the return road bedding the brakes and checking out the new transmission...if I had stopped right there things would have been peachy.
Made the first pass and the car yanked the wheels about two feet high on the launch. Felt alright going down track, but I could tell something wasnt quiet right overall. When I saw the timeslip I decided to fatten the carb and make another pass.
I planned on making this pass first before trying leaving on the two-step, so I stalled it up to 2800 and was really up on the wheel this time for the tree. When I nailed the throttle all hell broke loose under the car. I've broken my share of rear-ends over the years, but I never heard anything like I heard today...like the driveshaft was coming thru the floorpan.
With help the car was pushed backwards back into the staging lanes. I could'nt believe what I was seeing once I crawled under the car. At the hit it had folded the spring perches on the axle tubes like they were cardboard sending the center section pinion/yoke sky high into the floorpan. The most extreme pinion angle I have ever seen haha!
Made good use of the trailer winch today thank goodness. On the ride back home my partner and I debated the cause of this disaster, but neither of us could come up with a plausible explanation. Everything was dead-on straight, pinion angle at 4 degrees and the u-bolts were tightened to the point of deflecting the Caltrac brackets. We called a good friend and racer Perry Simpkins and he met us at the shop as we pulled in. Once on the lift Perry picked out the culprit...it was simply a failure of the spring perches themselves. Not enough bracing on the tubes.
Long story short...don't assume just because you bought the best parts they are the best parts. I'm probably going to have the housing doctored local instead of dealing with Moser. Had I known these perches were so weak beforehand I could have easily braced them myself from the beginning. Jeebus...work on a car all winter to make one pass.
Oh yeah Brent, you were asking about the trans crossmember. I had to drill thru the center for the cable...the only way the bracket was going to mount to the pan.
Rich Taylor
I/SA - 321
Old 03-02-2014, 12:05 AM   #56
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Holy Cow!
First off, I glad that your O.K., that is most important.
On my Wagon, I have 2" steel straps welded to the ends of the perch angled back to the axle tube on both ends.
Old 03-02-2014, 07:43 AM   #57
brent flynn
Dang! Im pretty sure that Moser would be getting a call from me, on this deal... THey should make it right. I had them do mine, about 12yrs ago, and ive had no problems...they must be using chinese parts... Now, i will look at mine...I think mine are stronger looking , if i recall...
Old 03-02-2014, 08:18 AM   #58
HandOverFist
The way it used to look hehe...
One would think that with a failure this quick I can't be the only one this has happened to. Btw, the Moser website really sucks.
Rich Taylor
I/SA - 321
Old 03-02-2014, 08:56 AM   #59
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Been there; done that. You will end up with something like this made from square or rectangular tubing and then boxed on the ends.
http://www.ebay.com/itm/LEAF-SPRING-...0994e8&vxp=mtr
Old 03-02-2014, 09:03 AM   #60
HandOverFist
Thanks Dwight...found something better at Calverts. http://www.calvertracing.com/store/h...pair-p-63.html
My question is why Moser did not use something better when they knew beforehand exactly what the intended application was.
Rich Taylor
I/SA - 321
