#31 | |
Ed Wright 4156 SS/JA Last edited by Ed Wright; 03-24-2014 at 08:27 PM. Reason: Still can't type. |
#32 |
I had a cool can in my old car. My new one will have one too. Out west and at altitude in temps above 65 it was worth .08-.10. Had to be careful if temp and DA dropped cause I actually failed fuel check once. Also ran the "plumbing insulation" from home depot on the hard lines to help keep cool in. Also this was on a "bypass" style system. constantly recirculating.
#33 |
Liked 2 Times in 2 Posts
What caused you to fail fuel check?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#34 |
Liked 606 Times in 213 Posts
In the late 60's and early 70's, it was common practice to use "cool cans", with ice around the fuel line....I believe it helped. When I got back into racing in 06, I asked the question: Why don't people use cool cans? I was told that the racing fuel used today does not react the same as "pump gas" used years ago....I don't know if that is true or not....
Gary Hansen - SS/FA 4911, B/SA 4911 |
#35 |
At Indy one year I put dry ice in my fuel jug (5 gallon jug with 4 gallons of fuel) Chilled the fuel down to 40 degrees. Made the run then went right to fuel check (first one down the track no waiting). You should have seen the look on the fuel guys face when he did the temp. But it passed with no problems.
Art Leong 2095 SS |
#36 |
That's what I was wondering... will they fail it on temperature alone? If so what are the parameters? Was your fuel 40* at fuel check or when you put it in the cell in the pits?
#37 |
Liked 166 Times in 54 Posts
When dad was driving and set the ihra rec I put some ice in the cool can ..and he picked up .08 and passed the fuel check. .....
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#38 |
I have had them take a second look at the temp, but never failed due to temp. As long as the other numbers come up OK.
Ed Wright 4156 SS/JA |
#39 |
Liked 60 Times in 12 Posts
Maybe they don't push that issue much. Mine's been there for 8 yrs, and I see several more. No tech guy has ever said anything about it, in D2,3 or 4. Or IHRA.
2894 STK |
#40 |
Liked 99 Times in 21 Posts
I won't get into the argument if it works or not, but the next time you are at Indy try to find some close by, bet all the local grocery stores are sold out.
