Old 04-05-2014, 12:39 PM   #1
Lyn Smith
Liked 973 Times in 195 Posts
Default J W Ultra bell installation
Installing a Ultra bell on my turbo 350 trans and kind of confused about the instructions.I plan on cutting the original bell off myself with a cut off wheel and die grinder,but it says in the instructions you must remove the front pump to do so.But why can you just trim it close,and finish up with the die grinder?Anyone installed one?
Old 04-05-2014, 05:54 PM   #2
E MAN 1982
Default Re: J W Ultra bell installation
Yes, you can do it. I've done it with a sawzall in an emergency at track. The trick is to get a nice line to follow. Also, you have to mask off the input/stator support area to keep out alum. chips. It may be helpful to remove and replace pump bolts and mask off holes as you go. E
E MAN  1982 is offline   Reply With Quote
Old 04-05-2014, 07:34 PM   #3
Don Anderson
Liked 24 Times in 8 Posts
X2 !!
Don Anderson is offline   Reply With Quote
Old 04-06-2014, 12:15 AM   #4
Lyn Smith
thanks for the info.
Old 04-06-2014, 10:16 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I drilled a series of small (.250") holes around the original bell housing from the inside, as close to the pump as I could get. Then, on the outside of the bell, I drew a line, connecting the holes for a cutting guide. The instructions give you a measurement from the mounting surface of the bell to your cut. Your guide line (holes) should be close to that measurement... I finished off my cut edge with a hand held belt sander, and some 80 grit..
I just masked off any openings in the trans and did my complete install with the trans together..
ID:	23248   Click image for larger version
Old 04-06-2014, 10:28 AM   #6
Lyn Smith
Thumbs up Re: J W Ultra bell installation
thanks for the pics Bob.I was thinking of drilling the holes as a guide line also.
Old 04-06-2014, 12:11 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
I have done several. Best off to measure back and make a rough cut short of the cut line. Then you can see exactly what you are doing. I used a 4 inch grinder with a cut off wheel to make the final cut. Then cleaned it up with a flapper wheel on the grinder. Take your time and measure twice. Double check to make sure the new bell is perfectly flush with the pump and is not touching the case anywhere. I have had real good luck on my powerglides.
Mike Pearson 2485 SS
