#171 |
Liked 33 Times in 16 Posts
I seem to be in a perpetual snake bite loop with this car. One qualifying pass this morning and I was rewarded with a cracked transmission case. There has to be some misalignment or binding somewhere. Body bushings look tight and fine...going to investigate the motor mounts before another transmission goes back in. I marked the crack in the case so it would show better in the photo's.
![]() ![]() ![]() ![]() Since I was pretty much useless for anything else I spent the day taking pictures and actually recorded every round. Too much video to upload in it's entirety, but I will put up part of a round and the final. ![]() ![]() ![]() ![]() ![]() Due to my no-show for the first round Brian Rogers got a bye with his bad to the bone D/S 302 '69 Camaro... ![]()
Rich Taylor I/SA - 321 |
#172 |
Liked 5 Times in 5 Posts
Dang,, Rich I'm sorry to hear that this car is putting you through the ringer so much. You know eventually it will get down the track, but I know (heck, we all know) that its very frustrating at times. I just got done with a trans R&R 2 weeks ago and hated cutting my new ATI converter open to clean it all out. Hang in there, we're pulling for you.
Danny Durham |
#173 |
I'm on a mission now...I will figure this one out. Some video's coming shortly.
![]() Love this car... http://s434.photobucket.com/user/ric...634d7.mp4.html The final... http://s434.photobucket.com/user/ric...4e331.mp4.html
Rich Taylor I/SA - 321 Last edited by HandOverFist; 04-20-2014 at 02:54 AM. |
#174 |
Liked 800 Times in 237 Posts
Rich, that's a darn shame. I was anticipating looking here this morning and seeing some positive results. No need to bore you with all the stuff to check....there was a good thread here recently on this same subject: http://classracer.com/classforum/showthread.php?t=52403
On the subject of motor mounts, I've got a set of Energy Suspension units to replace the solid mounts on my Nova before I take it out. Have a good Easter and keep us posted, okay? -Al
"That'll never work....." |
#175 |
Yeah Alan...there is an odd match of motor mounts which bugs me a little, but I'm unsure if they have any role in the current problem. The trans mount is urethane.
Driver's side... ![]() Passenger side... ![]() This car was as smooth as silk before the rear housing perch failure...ever since that time there seems to be an odd vibration at different points on the track. I wondered if it was just my imagination, but the car just doesnt feel the same since. I did replace the u-joints...how does one check the straightness of a driveshaft?
#176 |
Rich, I would defintely get the driveshaft to a shop and have it checked for straightness & balance. It's hard to tell from the pics, but check the motor mounts and make sure there's not a mismatch of heights....there is a 'tall' and a 'short' motor mount. -Al
http://www.jegs.com/i/Energy+Suspens...1114G/10002/-1
#177 | |
After giving it some thought I believe I'm going to just go ahead and have a new drive shaft built and change over to 1350 yokes...no sense to keep pounding on this stock 45 year old shaft and 1310 u-joints. My only other decision then will be using poly or steel motor mounts.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 04-20-2014 at 10:37 AM. |
#178 | |
Sorry, hadn't read all the thread, see you have urethane mount for the trans.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock Last edited by Robert Swartz; 04-20-2014 at 10:47 AM. |
#179 |
Urethane -
#180 |
Liked 3 Times in 1 Post
Broke a turbo 350 case in my Chevelle a couple years ago. I have steel mounts on engine and rubber on trans. My trans guy told me to make some spacer bushings at trans mount to leave a small amount of play in the mount -about a 1/16th. Had to open up slots in crossmember to fit. Trans guy does a lot of trans and anybody that has broken a case he has them do this with great results.
Dan Nugent H/SA N300 |
