Old 06-26-2014, 05:56 PM   #141
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
thanks Bob...yeah, im planning on it, at this point... Finishing up the 4.88s tonight...and just got to put weight in( about 50#) and get headrest in,..also, put the new belts in,and it should pass tech, just fine... testing next Wed, supposed to rain this weekend
Old 06-27-2014, 08:38 PM   #142
Originally Posted by brent flynn View Post
thanks bob...yeah, im planning on it, at this point... Finishing up the 4.88s tonight...and just got to put weight in( about 50#) and get headrest in,..also, put the new belts in,and it should pass tech, just fine... Testing next wed, supposed to rain this weekend
4.88's ??
Old 06-27-2014, 11:33 PM   #143
brent flynn
Why not? It should hit the traps about 6500-6600... it was only trapping at 5900 on a 11.59/115 pass with 4.30 ... i have 94'' radials and am at 3635 lbs in 'F' ... Im running a 251/256* Comp cam, in @ 105*, ground on 106 with 108LSA... if its way too much , i will drop back to 4.56s. The ATi converter flashed 4800 with the 4.30 .. it may tighten up slightly with the 4.88...
Old 06-27-2014, 11:50 PM   #144
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Sounds like it will be fine...looking forward to the results!
Rich Taylor
I/SA - 321
Old 06-27-2014, 11:56 PM   #145
brent flynn
yea, me too...but my shifter broke... was gettin ready to seat the gears in, and the lever fell off in my hand...
hurst 1/4 stick...gotta get it fixed , so i can test on Wednesday...hoping to go to Columbus 3rd week of July...
Old 06-28-2014, 08:48 AM   #146
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
That's the best place to break something. [in the garage] The dust and rocks aren't too friendly to lay on at Muncie.
Old 06-28-2014, 04:59 PM   #147
@ 6600 , you'll lose a MPH..which is what's going to happen, along with no 60' or 1/4 mi. et reduction.
Converter's too loose...Tighten converter, put good springs on it, keep the 4.33's
Old 06-29-2014, 03:46 AM   #148
brent flynn
well...i guess i will find out Wednesday...hehe I figured it would pick up, as i felt like the 4.30's were a little tall , for the converter... Im used to 455's, they like 5700-5800 trap rpm , with 4200 flash... i have a hard time believing that this deal willl nose over at 6200-6400... I figured 6500 or so, would be ok... I have a 4200 ATi, which i thought would be too tight, behind this engine....i thought 4.56 gears wouldnt be much of a jump... all i can say, is , i hope you're wrong... Will update Wed night, if weather is good for racing...
Old 06-29-2014, 07:42 AM   #149
Todd Hoven
Guest
Posts: n/a
Sometimes you have to go out and try different things. Nothing wrong with what Brent is doing. Flog that thing and figure out what it likes. At F weight in that bad summer Midwest air, it may not be as bad as you think.
This is what building and racing a class car is all about. Testing and finding your way. Good luck Brent.
Old 06-29-2014, 09:07 AM   #150
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Update E-F/SA Bird Build...
Todd, is dead-on about the Car telling you what it likes ? Keep testing & keep good notes , every- car is different... Watch the spring pressure , that's the key secret ? Good Luck & keep us updated ..
Dave Ribeiro 1033 STK
