#141 |
thanks Bob...yeah, im planning on it, at this point... Finishing up the 4.88s tonight...and just got to put weight in( about 50#) and get headrest in,..also, put the new belts in,and it should pass tech, just fine... testing next Wed, supposed to rain this weekend
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#142 | |
#143 |
Why not? It should hit the traps about 6500-6600... it was only trapping at 5900 on a 11.59/115 pass with 4.30 ... i have 94'' radials and am at 3635 lbs in 'F' ... Im running a 251/256* Comp cam, in @ 105*, ground on 106 with 108LSA... if its way too much , i will drop back to 4.56s. The ATi converter flashed 4800 with the 4.30 .. it may tighten up slightly with the 4.88...
#144 |
Liked 33 Times in 16 Posts
Sounds like it will be fine...looking forward to the results!
Rich Taylor I/SA - 321 |
#145 |
yea, me too...but my shifter broke... was gettin ready to seat the gears in, and the lever fell off in my hand...
hurst 1/4 stick...gotta get it fixed , so i can test on Wednesday...hoping to go to Columbus 3rd week of July... ![]()
#146 |
Liked 359 Times in 135 Posts
That's the best place to break something. [in the garage] The dust and rocks aren't too friendly to lay on at Muncie.
Who owns this car, with the peace sign,mag wheels, and four on the floor? |
#147 | |
Converter's too loose...Tighten converter, put good springs on it, keep the 4.33's
#148 |
well...i guess i will find out Wednesday...hehe I figured it would pick up, as i felt like the 4.30's were a little tall , for the converter... Im used to 455's, they like 5700-5800 trap rpm , with 4200 flash... i have a hard time believing that this deal willl nose over at 6200-6400... I figured 6500 or so, would be ok... I have a 4200 ATi, which i thought would be too tight, behind this engine....i thought 4.56 gears wouldnt be much of a jump... all i can say, is , i hope you're wrong... Will update Wed night, if weather is good for racing...
#149 |
Guest
Posts: n/a
Sometimes you have to go out and try different things. Nothing wrong with what Brent is doing. Flog that thing and figure out what it likes. At F weight in that bad summer Midwest air, it may not be as bad as you think.
This is what building and racing a class car is all about. Testing and finding your way. Good luck Brent. |
#150 |
Liked 56 Times in 27 Posts
Todd, is dead-on about the Car telling you what it likes ? Keep testing & keep good notes , every- car is different... Watch the spring pressure , that's the key secret ? Good Luck & keep us updated ..
Dave Ribeiro 1033 STK |
