Old 05-10-2014, 09:18 PM   #71
Robert Swartz
Robert Swartz's Avatar
Default Re: 1978 Mustang II
Well spent today (Saturday) working on the Mustang II. After unbolting the R&P, that released the steering shaft. Once that was accomplished, the driver side header, pretty much slid into place. Only have them mocked up for now. Wanted to see if I had any clearance issues. Only current problem I see are the lines to the transmission cooler. John Pressing, if you read this, the headers fit great.
I've also measured out where the driveshaft loop needs to go. As well, I mocked up one of the universal traction bars. Looking at these, they just might work with minimal modifications. Originally, I had planned to cut the brackets off and weld them to another set of spring pads. I may be able to weld a couple of bars onto the bottom of these to make them adhere to the present spring pads. In addition use Billy Nees suggestion to clamp the springs. Just might have a workable combination here.
I have a laundry list of things to do to this car. I'd like to think I made some progress, in truth feel I've only created more work, LOL!
Name:	header driver side.jpg
ID:	23738   Click image for larger version
Name:	headers under car.jpg
ID:	23739   Click image for larger version
Name:	trac bar universal.jpg
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 07-12-2014, 09:01 PM   #72
Robert Swartz
It's been awhile since any real progress on the Mustang II has yielded any results. Finally something to report. We're not ready to race the thing yet, not by a long shot. It is getting close enough to maybe, get it to a track before long.
Finally got the new rear under the car. Upon taking it apart, the rear brakes were trashed. The shoes were eaten down to the rivets. Both drums had nasty grooves dug into them. A trip to the parts store and new shoes, drums and a hardware kit were purchased. It's been at least 5 years since I've done a set of drum brakes. I had forgotten how enjoyable it is to do them (snark intended)! My one screw up, I got the shoes reversed on one side, couldn't get the drum on. Thankfully, we only tore down one side at a time, after looking at the opposite side, saw the problem, lol.
After finishing the brakes. New studs were installed in the axles. When we installed the rear, it pushed one of the studs in, had to pry it back out and reseat the stud. Only got a couple smashed fingers and a blood blister to show for this. Rear end is in place and new wheel studs installed. Just going to use the stock axles for now. After we get the car sorted out, I'm going to get a good set of axles.
Then we removed the front seats and installed the driveshaft loop. I think that was the easiest part of the whole day.
Next I have new rotors and pads for the front. Get the long studs on them as well. I'm getting antsy. We think we're going to put the MSD dist in, redo some wiring. Put the new water pump and fan on it. Then wire up the tach and gauges. Haul the thing to the track and bracket race it some.
Wish I could be as close as Brent and Rich are. It's just not ready for Stock, yet.
Name:	Driveshaft loop under car.jpg
ID:	24719   Click image for larger version
Name:	DS loop side.jpg
ID:	24720   Click image for larger version
Name:	rear view studs.jpg
Name:	wheels with new studs.jpg
Old 07-12-2014, 10:57 PM   #73
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You may be closer than we are buddy!
Rich Taylor
I/SA - 321
Old 07-19-2014, 07:16 PM   #74
Robert Swartz
Spent today getting some things done to the Mustang II. We removed the old water pump. Took off the PS pump and all the old brackets. Boy, that cleared up some space. Gonna flush out and clean up the radiator. Reroute the transmission cooler lines and add an exterior trans cooler. For the time being removed and looped the PS lines to the steering box together. Poor mans manual steering. Eventually I'll get a manual rack and change it out.
For now we only have the water pump mocked up. Need to work on some different spacers. Figure out some belt length. Had to scavenge a backing plate from an old water pump and made a couple simple modifications to it. Not happy about having the car down. Not everything goes together as simply as I'd like.
Old 07-20-2014, 12:26 PM   #75
Old 07-20-2014, 09:28 PM   #76
Robert Swartz
Spent a few minutes swapping bolts and spacers. After looking at a picture of a similar setup. Moved the aluminum bar around. This might be the best arrangement. Still need to determine a belt. This setup would allow me to use the fancy adjustment bar with the heim ends.
Got a pm from Mark. My converter is done. That changes the dynamic. So close, yet still so far.
Old 07-20-2014, 10:22 PM   #77
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Hello, i have a question when you said the "pads were reversed" on the rear. I just did a 9 inch rear for a friends 64 Falcon. It was a junkyard rear that I started with without brakes. I believed I assembled the brakes right using a diagram, but one side the drum is tight. Seeing this is my first Ford experience i seem to run into these problems (on third set of front spindles-right now) Could my pads be "reversed" They seem to be the same side to side> I do.t want to hijack this thread, but i could use some help.
Will Lamprecht I/SA 65 Impala inprogress.
Old 07-21-2014, 12:57 PM   #78
Liked 5,129 Times in 1,956 Posts
Will , Robt. was talking about rear "shoes" not pads. And no , switching a primary shoe with a secondary won't, in itself prevent the drum from slipping on.
New drums, news shoes....you're gonna start out on the tight side. I suspect the shoes weren't centered..that's all.
Old 07-21-2014, 02:50 PM   #79
B/S 428
Liked 154 Times in 34 Posts
hi-I was wondering about the correct carb size for this combo-I looked on the NHRA website and it does not list venture size? tried researching the part number listed and found it is a 1.21 not a 1.08? thanks-Brian
B/S 428 is offline   Reply With Quote
Old 07-21-2014, 03:48 PM   #80
99 % of the 302 2v's have to use the 1.08 carb.
Apparently there is one that can use the 1.21,, but I'm gonna stay out of that situation.
