Old 08-28-2014, 10:26 AM   #21
joe cool
Liked 5 Times in 3 Posts
Default Re: 1957 chevy in stock
So I assume I would not be allowed to install a crossmember, but would need to fabricate a side mount setup.?
Joe Keightley
Pacific Junction Iowa
joe cool is offline   Reply With Quote
Old 08-28-2014, 01:32 PM   #22
Originally Posted by Dave Noll View Post
OK I'm just a Ford guy asking this. A 57 has the motor mounts @ the very front of the block and, if I remember right, a mount on each side of the bell housing. Then the trans just hung from there. @ least this is how a 57 Pontiac is, (I had 1). My question is this; how, under Stock rules are you going to put a Metric trans in that ?
David, The aluminum PG has been a super-ceded replacement for the cast iron one for a long time. Of course, it has a rear mount, same as a T200. So yes , you can use a rear cross member to hold it up.
The front mounts are far enough apart to hold it in place. Not exactly the same as the early Corvette, but similar.
You could add a torque strap , and I believe it would be fine.
The early Pontiac was a bit different. It was a horseshoe deal with a center pad.
That wouldn't work without bell housing or side mounts.
Old 08-28-2014, 03:03 PM   #23
Jim Cimarolli
Liked 166 Times in 46 Posts
Question Re: 1957 chevy in stock
I think the question kind of boils down to: Can you legally install side motor mounts on a Tri-Five Chevy for stock eliminator?
Jim Cimarolli is offline   Reply With Quote
Old 08-28-2014, 04:02 PM   #24
Jimmy, You and I wouldn't get away with it..Maybe someone else would.
Old 08-28-2014, 09:46 PM   #25
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Thank You, Mark. I don't think I would be comfortable with that long distance between mounts on the Chevy, but somebody must be running it that way. Yes the Pontiac had one mount @ the front & it was bolted to an iron timing chain cover.
Dave Noll, EF/S ,?/SA 6526
Old 08-28-2014, 10:07 PM   #26
Jim Cimarolli
Cool Re: 1957 chevy in stock
I ran SS back in the 70's with my old 57 wagon, (Still got it, turned it into a street car). I used the old '57 265 block, so it didn't have the side mounts on the block, and I had an aluminum Powerglide transmission. I made a rear crossmember, and fabricated a drivers side torque arm that bolted to the bellhousing and had a mount on the frame with a rubber cushion between them. Worked fine with a small engine/low hp.
Old 08-29-2014, 03:55 PM   #27
joe cool
A mid plate to use stock type frame mounts?
Joe Keightley
Old 08-29-2014, 05:14 PM   #28
Logus
Not necessarily the best, but the idea may work in low hp setup.
http://www.chevyclassicsclub.com/wp-...Chevy_tech.pdf
Logus is offline   Reply With Quote
