#41 | |
Liked 275 Times in 76 Posts
Rear Suspension parts, Metco. Also you can only relocate the upper control arm, so nothing adjustable on the lowers. Good struts and shocks. Aftermarket springs are overrated, and a waste of money. Shocks and struts are where its at. No anti-roll bar is needed with good shocks. Sean
#42 |
Liked 33 Times in 16 Posts
Good to know about the sway bar...it will be deleted then. From what I gather a set of well worn GT springs work better than anything, maybe with a coil cut out. Just so happens there is a set already in the car.
Rich Taylor I/SA - 321 |
#43 |
I have three different sets of springs. The original 83 GT springs with a coil cut, for K/S, and now an uncut 90 GT set for L/S, and a set from a Faimont wagon. The wagon springs were way too much for L weight.
The smallest tires ever on the car were Goodyear 28" but that has been many years ago, and with 5.13 gears. When I decided to do the bodywork and paint is when I was able to go to the 29.5 stick MT's. Unless you put a 9" in it you are screwed with gear selection. Also only street gears are available for the 8.8, which I have only had 2 sets in the car. The pinion gear stress fractures and starts cracking. High RPM launches and having the clutch set too tight doesn't help their life span. For gears, Motive sells a lightened 8.8 set, welding the tubes to the center section is not a absolute have to deal, but highly recommended. Installing an LPW rear cover to preload the bearing caps, you may already have one on the Camero. An 8.8 and 12 bolt are very similar in design. Sean
#44 |
Thanks Sean - This being an automatic car I'm sure will cut the stress off those gears. My thoughts on the smaller tire were with the auto in mind as well.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 10-23-2014 at 02:43 PM. |
#45 |
Plans for this weekend are to begin stripping the interior out of the car in preparation for welding of the subframe connectors and roll bar. Parts to begin drifting in next week...roll bar is being built, expect 3-4 week time frame.
Bought a Team Z UCA kit today for the 8.8 housing... ![]() I'll couple these with some Southside Machine copies of LCA's... ![]() I will be changing the interior color with Black carpet and painting the dash/console either White or Black. ![]() Tentatively planning on removing the E-brake lever and mounting the shifter in that recessed area. ![]()
#46 |
Got a little something done today...stripped the interior and trunk area. Next will be removing all the rubberized sound barrier from the pans...oh boy. Following that will come under dash gutting and removal of inside door reinforcement bars. Parts are piling up fast...
![]() ![]() (See the gaurdrail inside the door?) ![]() ![]() ![]() ![]() ![]() ![]()
Rich Taylor I/SA - 321 Last edited by HandOverFist; 10-25-2014 at 08:22 PM. |
#47 |
Liked 19 Times in 12 Posts
What type? Brand?
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#48 |
http://www.maximummotorsports.com/MM...bare-P580.aspx
Same folks are building a roll bar for me right now.
#49 | |
#50 | |
I'm going to need another deck lid...stupid spoiler sat up there loose for so long it ate on the lid pretty good. ![]() ![]()
