#71 |
Liked 7,778 Times in 1,742 Posts
You can call it whatever you want. It's what the NHRA Tech people call it that will matter. I was called out over some mods that I made to my stock tank by my Div. Tech Director who considered it a safety issue. It seems the NHRA doesn't want just anyone that may not be qualified modifying gas tanks.
#72 | |
Liked 147 Times in 54 Posts
Randy Hyman. Lakewood co. stk 5394 P/SA |
#73 |
Liked 33 Times in 16 Posts
That spoiler looks even better on top of that growing heap outside the back door hehe.
Rich Taylor I/SA - 321 |
#74 |
Work continues albeit at a snails pace. Forgot just how taxing this is by yourself...makes you grow extra limbs and such lol.
Subframe connectors and control arm box reinforcements are in, but my Mig welder has given up. Once I have the roll bar I'm taking it elsewhere to get everything stitched properly. I forget what the name and purpose of that big honkin metal appliance is under the differential snout. Is it a necessary item? I've given up on the new fuel tank idea...appears it would not meet the rulebook criteria. I guess it will be either the factory piece or a fuel cell now. ![]()
Rich Taylor I/SA - 321 Last edited by HandOverFist; 11-02-2014 at 07:35 PM. |
#75 |
Liked 223 Times in 73 Posts
That part is not needed. Weight it and chuck it in the scrap bin.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#76 |
Liked 19 Times in 12 Posts
How about something like this? Works with the factory setup.
http://www.jegs.com/i/Russell/799/64...ductId=1329877
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#77 | |
These fittings would help in not having to buy new fuel rails... http://www.latemodelrestoration.com/...il-Adaptor-Kit Edit: I see now what you were getting at Charlie...those fittings are for if you intend to retain the factory steel supply/return lines. Those would save the cost of fuel lines from the front/back of the car.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 11-03-2014 at 01:17 PM. |
#78 | |
Happy Mustang !! |
#79 |
I really liked the idea of using the factory fuel system at first, but I'm less warm about it atm. I understand the weight benefit, but at today's prices that is some expensive ballast...and it would keep disappearing lol! It could still happen tho. How far under the index is your car atm?
#80 | |
I do alot of local bracket racing, on pump gas, 120 lbs heavy on bias tires at .30-.40 under. |
