Old 11-12-2014, 06:39 PM   #131
87gt50
Default Re: Ford vs Chevy Build-up
I have used a spring compressor designed like this to remove/reinstall uncut Moroso drag springs on my fox several times. Access to the tool through the hole in the center of the spring perch on the a-arm, and make sure you get as many coils as possible included in the compression.
Btw, keep up the good work, you will have lots of fun with your Mustang!
87gt50 is offline   Reply With Quote
Old 11-12-2014, 07:59 PM   #132
SSGT Mustang
Liked 204 Times in 54 Posts
Originally Posted by HandOverFist View Post
That's good because this one no longer has an air bag either.
Got those 4-cylinder springs today...I'll tackle those this weekend.
Compressors never worked for me. I use an old fashion 3-4 foot crow bar with an angled tip.
I lower the front of the control arm while it's bolted onto the k-member. I put the spring in place (it will only seat about half way in at the bottom, maybe less). I wedge the crow bar into the control arm spring pocket (using the angled tip pointed downward) and push the spring backward while jacking up the front of the control arm. Reinstall the struts bolts. Move to the next spring.
You can get springs in your car in about 10 minutes this way.
I know it goes without saying, but you need to be careful. Make sure that you and the guy jacking the control arm are not standing in front of the spring in case it decides to go airborne.
SSGT Mustang is offline   Reply With Quote
Old 11-12-2014, 09:14 PM   #133
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I have one of these, made a flat plate on the hex end, and went up thru the bottom of the control arm,hooking the upper hooks on the spring.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 11-13-2014, 01:45 AM   #134
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Yep, that's mine. I removed two of the hooks to make it fit in the spring and reconnected them inside it to finish the job. Lots of painful short radius wrench work.
Dale
Old 11-13-2014, 02:36 AM   #135
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Thanks guys - Our spring compressor consists of flat plates and has been used on all springs installed in Chevrolets...I suspect it will work just as well on the Ford. I have never installed an uncut Moroso spring in any car myself. Hope these springs work out the first go round.
Rich Taylor
I/SA - 321
Old 11-17-2014, 01:12 AM   #136
HandOverFist
Car is at a friends machine shop for the roll bar finish welding. I'll tackle the front-end when he is finished.
Let's talk headers - While I'm not at that point yet I ran across a good deal...if they will work on this combo. A used set of long tube stainless Kooks, 1-7/8" primaries, 3.5" collectors, $550...to large for this engine?
What are you fellows using on similar cars?
Rich Taylor
I/SA - 321
Old 11-17-2014, 03:18 AM   #137
FireSale
FireSale's Avatar
I can't speak to the clearances in your car, but I have Hooker Super Comp long tube headers on the 302 in my 68 coupe and getting at the header bolts is beyond painful. I have looked up header bolt solutions on the Net and I keep coming up with "Header Clearance Issue on Vintage Camaro" in the Ford searches so maybe it's not badge specific. The bolts to the lead side of the pipe aren't too bad but the ones on the back of each bend are super tuff to get to. I have a mix of bolts depending on what I could get to fit.
Power or manual steering? Better clearance on manual boxes.
Mine are 1 5/8 by 3 1/2 and I can't imagine larger ones on that engine. People do it but they cut the shock towers out, too.
Dale
Old 11-17-2014, 08:21 AM   #138
Dave Gantz
Liked 251 Times in 125 Posts
Dale
Been a while since I've been involved, but I'm pretty sure there's no cutting shock towers in Stock Eliminator.
Old 11-17-2014, 10:08 AM   #139
HandOverFist
Well, with no part number disclosed I did a little deeper research on Kooks. It appears those headers would not fit with a stock K-member and likely would not even bolt-up to standard port heads. I was also advised that overall those headers were way too large for this combo.
Rich Taylor
I/SA - 321
Old 11-17-2014, 11:36 AM   #140
slowpony
For what it is worth, my research indicates that 13/4 is as big as you would want to go with stock heads, and that is with mufflers providing back pressure. 15/8 open with stock heads seems to be the standard. I am talking about long tubes. I am looking at 13/4 with full exhaust for Pure Stock.
slowpony is offline   Reply With Quote
