Old 01-10-2015, 08:30 PM   #201
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Almost finished with the interior...home run or foul?
Rich Taylor
I/SA - 321
Old 01-10-2015, 08:53 PM   #202
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Looks good.
Old 01-11-2015, 01:15 PM   #203
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Slick looking. Does the seat back need to be braced to the cross bar or is that an ET/speed or class specific rule?
Dale
Old 01-11-2015, 01:28 PM   #204
HandOverFist
Dale
The seat back is fully against the cross bar. I don't know of an effective way to bolt a factory seat back to a cross bar...our Camaro is the same with factory seats.
Rich Taylor
I/SA - 321
Old 01-12-2015, 07:38 AM   #205
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Pull off the upholstery and make up/ weld a bracket to protrude through the back of the seat that will allow it to bolt to the bar?
Mitch Beri- The Motor City
Old 01-12-2015, 07:41 AM   #206
black88coupe
The white is a bit much for my tastes but it's your car so do whatever makes you happy. A for effort.
Old 01-12-2015, 10:27 AM   #207
HandOverFist
There is very little to no metal in the seats to bolt to. Even in a '67 Camaro the seat back is merely some thin stamped vinyl covered metal attached to the back with one clip up top and two upholstery screws at the bottom. It would be a useless exercise for little gain in my opinion.
Rich Taylor
I/SA - 321
Old 01-12-2015, 11:09 AM   #208
FireSale
FireSale's Avatar
Regarding the seat back, since you have the same type of seat in the Camaro you shouldn't have an issue with track officials on the Mustang.
Unless they are really upset when you pull up with a F**d in tow....;-)
Dale
Old 01-12-2015, 11:17 AM   #209
HandOverFist
Come to think of it, I don't recall ever seeing a factory seat in a Stocker reinforced in the manner described. If someone has one or pictures of one I would like to see it.
Rich Taylor
I/SA - 321
Old 01-12-2015, 11:53 AM   #210
FireSale
FireSale's Avatar
This is out of a 'Vett forum dated 2011. Very similar to your roll bar and seat set-up. Seat back contacts the cross bar and the headrest is fixed to it by a slip pin.
http://www.corvetteforum.com/forums/...post1577731913
Dale
