Old 02-15-2015, 06:20 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Master Cly Install Help
Tom - Don't know about Lamb, but Strange recommends using the rear port to the brakes which require the most volume. Using four-pistons front and rear on ours I just plumbed as usual with the rear port serving the rear system and used a 2lb residual valve in that line.
Rich Taylor
I/SA - 321
Old 02-15-2015, 07:03 PM   #12
Tom Meyer
Liked 354 Times in 120 Posts
I will check with Lamb on Monday, this is turning into a real search to find fittings to get this to work and look nice. Spent most of the day looking for stuff when I could have been working on the car. Like I said before it worked fine with the stock master cly and now I try and make it better and struggle big time. Thanks to all Tom
Tom Meyer 5240 SS Stock ???
Old 02-15-2015, 09:10 PM   #13
Alan Nyhus
Liked 799 Times in 236 Posts
Tom, the Dorman number for a 1/2"X20 nut for 3/16" tubing is 490-302. For 1/2"X20 1/4" tubing it's 490-305. In the link I posted earlier they are refered to as 'Oversize Tub Nuts'. The 'oversize' refers to the fact that the nut is larger than the normal brake line nuts for a specific tubing size. -Al
"That'll never work....."
Old 02-15-2015, 09:25 PM   #14
Run to Rund
Liked 54 Times in 27 Posts
I found some short lines with the big nuts on one end, and regular line nuts on the other. Pep Boys had various such lines.
Old 02-16-2015, 02:25 AM   #15
GTX JOHN
80s Dodge full size PU havr them
The Cylinder I use is proportioned 69 Front and 31 Back
John Irving
741 Stock
741 Super Stock
Old 02-16-2015, 08:16 PM   #16
ss wannabee
Liked 7 Times in 7 Posts
Would the BR-150 and BR-155 tubing nuts from the SUR & R company be the ones
Tom is looking for? If so, available from some auto parts stores...as well as Summit
Racing.
ss wannabee is offline   Reply With Quote
Old 02-16-2015, 09:55 PM   #17
Tom Meyer
Got it covered today with a call to Roger Lamb [great people] but he did have to go dig for them. Also on my app rear line goes to front brakes front line to the rear. I want to thank every one for your help. Tom
Old 02-16-2015, 11:27 PM   #18
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Tom, does this mean we'll see you out this year?
Paul Merolla is offline   Reply With Quote
Old 02-17-2015, 05:52 PM   #19
sugar1366
Napa/Gates Part #G49504-0303 adapts 9/16-20 to 3/16 female inverted flare.
I know you got it solved already, but thought I would put the info out there for future reference.
Eddie Bolton
sugar1366 is offline   Reply With Quote
