Liked 173 Times in 52 Posts
I have a 24ft enclosed trailer with an untreated, unpainted floor. Been kicking around putting a snap together floor like 'Race Deck' or 'Swisstrax' but I've not seen it used in a trailer before. I've seen some with spray on bedliner which is ok but I know it can be slick under some conditions. Not crazy about the vinyl checkerboard.
Saw this stuff, ArmorSeal Tread-Plex Water Based Coating, looks interesting. As usual I'm probably over thinking this a little. Thoughts and opinions are appreciated Kelly |
Liked 336 Times in 183 Posts
your question really all comes down to PRICE-- how much do you have to spend??? There are multiple options for finishing the floor some not overly expensive coverings might be (paints etc.) to very expensive coverings (Coin type vinyl/rubber flooring or aluminum diamond plate) its the look you want to achieve and the amount of money you have to spend on your floor--FED 387
Liked 56 Times in 29 Posts
cost, and weight! I just used latex based paint on mine, easy to touch up, and fine unless you create an exxon valdez on the floor.
Liked 33 Times in 20 Posts
My neighbor at NMRA Bradenton has installed laminate wood flooring.
He had it installed over the plywood floor and finished the edges with 1/4 rounds. It looks really good. The car was a light weight mustang, big slicks. |
Don't use aluminum diamond plate it's extremely slippery when wet!
![]() I have used indoor out door carpeting but you need to glue it down and it's a PITA to remove. Cheap vinyl tile will not hold up for long. I haven't tried vinyl flooring yet. I would at least paint it.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 03-19-2015 at 08:44 PM. |
#6 | |
Liked 2,023 Times in 607 Posts
any sort of vinyl tile or flooring will not hold up. There are some rubber type tiles that would but the cost would probably be as much as the tread plate.
Mike Pearson 2485 SS |
Liked 1,887 Times in 579 Posts
i like the idea of line-x type of coating, bring it up the sides a bit, then you could go in and wash out any dirt-mud etc. that being said I have the rubber coin floor in mine and I had to power wash out all that atco mud from last years div race. no problem just didn't want it seeping in the side joints
Got a quote for LineX, $1200. I may look into a do it yourself spray in kit.
Thanks for all your input. |
Liked 293 Times in 65 Posts
I used a latex-based porch / floor paint from Lowe's. Light gray, and it comes with sand mixed in so it doesn't get slick. We went up the walls to the height of the wheelwells, and I think it looks pretty good. Spent maybe $120 all said and done, but this will only be the 2nd season with it so I'm not sure how long it will last.
