After 14 years of Pro Bracket racing my 69 Camaro with a 302ci and 327ci, and a wide ratio auto gear 4 speed, I have built a 406ci small block bracket engine to replace my smaller engines. Have been running 11.27-11.6's with the 327 this year. I plan on tuning the 406 to run 10.9 with a throttle pedal stop under the accelerator pedal, keeping the timing around 32 degrees and running a 750 carb. I plan on "not" running the engine "all out" and racing more like an index racer. Does anybody feel like this would be advantageous for Pro Bracket racing? Or a mistake? Suggestion's please.
#2 | |
Liked 226 Times in 115 Posts
I don't think there's a right or wrong answer to your question. IMO, I would run the motor all out, then detune just a tad. Usually 1-3 tenths works for us. There are other factors we take into strategy also. |
Liked 124 Times in 44 Posts
Sam, are you selling the old engines?
I have my 327 block,+.040,1967 date code, small journal, .875 lifter bores, hardblok to the water pump.........Not sure if anyone would be interested. would consider selling.
