Old 10-18-2015, 11:01 PM   #1
rick lester
Liked 4 Times in 1 Post
Default 1978 Dodge Magnum stocker?
I love oddball combos, this might not be an oddball but I would like to get an opinion on if this is viable. Its heavy, can be run as a 2 brl or a 4brl with a intake /carb switch (same cam and heads for either). Wants a grand but probably can get it for 600 or so. IF I do pull the trigger, you can count on a post by post build up here. N/O/P as a 2brl, L/M/N as a 4brl.
rick lester is offline   Reply With Quote
Old 10-18-2015, 11:17 PM   #2
rick lester
Default Re: 1978 Dodge Magnum stocker?
Tried to make the picture bigger but I failed miserably.
Old 10-19-2015, 07:56 AM   #3
Billy Nees
Liked 7,783 Times in 1,743 Posts
With the 4bbl it's OK but the 2bbl would need about 20 HP back to be worth your while.
Billy Nees 1188 STK, SS
Old 10-19-2015, 12:03 PM   #4
Agreed
gif image hosting
Old 10-19-2015, 01:35 PM   #5
Paul Wong
Liked 419 Times in 85 Posts
the 360 270hp is the way to go. It would run under the index cheap.
Paul Wong is offline   Reply With Quote
Old 10-21-2015, 08:41 PM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 1978 Dodge Magnum stocker?
Listen to Paul Wong. Incidentally,do these cars have the long straight front torsion bars,or the removable front K member with the bent bars contained in it?
Old 10-21-2015, 11:16 PM   #7
House of Darts
Liked 20 Times in 15 Posts
Just like the B Body.
House of Darts is offline   Reply With Quote
Old 10-21-2015, 11:17 PM   #8
rick lester
Honestly I couldn't tell you Greg.
If I pull the trigger, this will be my first Mopar build so all the help/suggestions/honest know-how will be appreciated.
If I do this, I will be using the 360/170/276 motor.
Will the 904 bolt up?
I'm inclined to think a 8 3/4 rear will be plenty?
Long way off but Sox and Martin red, white and blue, or a simple Petty Blue?
Old 10-22-2015, 09:33 AM   #9
kansas stocker
Liked 249 Times in 48 Posts
yes on the 900 series transmission.
yes on the 8 3/4,done correctly.
red, white, and blue on the color.
kansas stocker is offline   Reply With Quote
Old 10-22-2015, 11:49 AM   #10
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Not a wrench turned and you are already concerned about a paint job? Dream on.
