#11 |
Liked 317 Times in 108 Posts
looking good,Bill
Mike Taylor 3601 |
#12 |
Liked 9 Times in 8 Posts
The rest of the sheetmetal parts are down here....
__________________ Bill Diehl B200 C/D STK |
#13 |
I was going to rebuild the factory headlight assemblies..but being 45 years old and they looked like they were 145 years old, I got these instead.
These things are really nice even if they are offshore clones ![]()
#14 |
and they will bolt on to this....
#15 |
If it wasn't a cleveland I wouldn't be using these, but it does make for a nice way to restrict the oil, should have posted them a few pics back with the rest of the cam gear
#16 |
Liked 237 Times in 126 Posts
Looks nice. What's your source for sheet metal? I used mostly Dynacorn stuff from CJPony Parts to rebuild my 68 coupe. Floor pans, radiator support, a fender and such. Pretty descent stuff for Korean stamping.
I don't have access to a rule book on this computer but I think you are allowed to cut that cross member for header clearance. Dale
#17 | |
I am tig welding all the panels back in also, but its a slow process in between bending tubing for the roll cage and pouring concrete for a living Headers where designed for the engine to sit lower.....but rules state I cant do that, raise the engine to stock location they hit the floor, lower the engine hits the crossmember..no problem, I have a plan wish I could use a dif intake manifold though, I have the best set of heads on the planet (nobody has anything close) with the worst manifold bolted to them
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 11-11-2015 at 01:46 PM. |
#18 | |
Liked 240 Times in 112 Posts
Can those cam beearings be used with an iron cam ? Comp told me 400lbs open was about it for an iron cam but those 1427's are 500 @ .600" so a tick less with the Boss cam. ![]() ![]() ![]()
Dave Noll, EF/S ,?/SA 6526 |
#19 | |
#20 |
The exhaust crossover, lead is too much of a hassle, tin leaks....aluminum plate works much better and don't have to worry about anything falling out or finding its way into the exhaust bowl. and I am able to swap manifolds without screwing around with it.
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 11-12-2015 at 09:04 AM. |
