#11 |
Liked 99 Times in 60 Posts
#227 shows what can be considered "big lift"
#229 shows the 60 MM cam journal. Monte says it looks like the engine has two crankshafts #230 shows the cam at 113* per the cam card #231 cam at 113* and intake valve a full "big lift" ![]()
Larry Woodfin 471W |
#12 |
so you can see part of the vision
#13 |
I like beautiful and shinny parts. Check this outstanding work by Dan Olson oil pans.
#14 |
A good work day - planning day for the Roadster
#15 |
At Woodfin Automotive we work on EFI equipped cars and truck most every day. Yet, we do not race those cars ! Nor do we engineer the systems, we simply repair them.
Our roadster is not only a new exercise in drag racing with EFI it also requires some home spun engineering. In keeping with the basic theme of hot rodding if you are not modifying or customizing every part on the package you are being remiss. The engine is a Brodix aluminum block with raised cam and raised deck. EVERYTHING that bolts on the block requires some tweaking. Here I am spotting the magnet bolt that will screw into the cam gear. The magnet is set at 195 degrees before TDC #1 firing. It identifies the #1 cylinder position for the ECM and begins the injector firing sequence.
#16 |
the cam sync sensor tucked behind the water pump
bolt with magnet in head for sensor signal
#17 |
Q - What is required if the fenders need to be wider? If you want the tire tread under the fender?
A - Modification! Simply cut off them off, splice the width, reinstall. No hill for a hot rodder ![]()
#18 |
Q - How many ignition coils does an Holley Dominator EFI system need?
A - All of them!
#19 |
Liked 491 Times in 229 Posts
Coming along good ! How son you think it will be on track testing ?
Jake Biermann |
#20 |
Jake, first runs are some months away. many details yet to attend
