#81 |
Liked 223 Times in 73 Posts
And today I sprayed the rest of it. I think I moved the sprayer too fast on the last coat of clear, resulting in lots of orange peel. A couple of other flaws as well. But with three coats of clear I think it ought to sand and buff out okay.
If I get a mirror finish, it'll only highlight the flaws in the body work anyway! ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Dave Muller; 07-07-2017 at 10:18 PM. |
#82 |
Liked 33 Times in 16 Posts
Good job Dave! I sprayed today as well...feeling fortunate I had only one small run and it was in the second coat of base.
Rich Taylor I/SA - 321 |
#83 |
Liked 53 Times in 16 Posts
Looks great Dave,
With my car I just painted, Contingency decals and lettering to cover up spots I don;t like~! Will Lamprecht 65 Impala I/SA in progress |
#84 |
Our Camaro needs lots more decals lol...
#85 |
You know, that's funny, I was just thinking about what I could get lettered on the trunk to hide a couple of bad spots there!
#86 |
I haven't gotten to the fenders and hood yet but the rest of it is now sanded and I just finished the first round of buffing, with coarse compound. It already shows the beginnings of a shine.
Now it's time for beer and wings, and watching guys give each other concussions. ![]() ![]() ![]() Last edited by Dave Muller; 07-07-2017 at 10:21 PM. |
#87 |
It's nice to finally be back to doing some mechanical work.
After taking care of a few details like a timing pointer: ![]() And a pulley for the water pump, which had to be cut down for clearance: ![]() I always fabricate a jumper to the solenoid and run a Ford-type solenoid on the inner fender. I hate the idea of having a cable with live 12 volts next to a hot header: ![]() Finally I installed the engine and transmission: ![]() ![]() Last edited by Dave Muller; 07-07-2017 at 10:26 PM. |
#88 | |
Liked 373 Times in 129 Posts
#89 |
#90 |
A big part of why I like projects like this is working through all the little design issues, even the trivial ones. Like mounting the line-loc solenoid.
I've always mounted them on the inner fender in the past, but this time there were a couple of happy little bolts by the master cylinders saying "Use us! Use us!" So I did, starting out by making a template: ![]() Then cutting it out from a 1/8" sheet of aluminum and drilling it: ![]() Then I mounted the solenoid and bolted the plate in place. ![]() ![]() Now all I have to do is bend the existing lines slightly and they should line up with the fittings that I'll be adding shortly. The only new line I need to fabricate is a short one to the solenoid inlet. Last edited by Dave Muller; 07-07-2017 at 10:29 PM. |
