Old 02-17-2016, 03:00 PM   #111
SSDiv6
Default Re: Boss Mustang stocker
Originally Posted by astikhossw View Post
So Bill i have a question about your front suspension is that the picture of the stocker boss suspension that you are planning on running in stock.Just curious????
If you read the posting, is the suspension from Bill's other Mustang; a 1998 SN95.
Old 02-18-2016, 02:53 PM   #112
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
I have been debating with myself if I wanted to bump this project up a few classes, as of now it still remaines a "stock" eliminator.
With that being said it will have a stock 71 mustang front suspension which consits of upper and lower control arms with the spring and shock exactly as produced by ford for the 71 model year
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 03-26-2016, 06:43 PM   #113
Bill Diehl
Bill Diehl's Avatar
It will stay as a stocker...getting all the new metal to fit is a royal pain in the....
Old 03-27-2016, 08:59 AM   #114
Bill Diehl
Bill Diehl's Avatar
Just when you think you know everything about everything, something always comes along to prove you wrong.....the first thing to do with any "restoration" is write down all the measurements before taking it all apart...I did not do that
Old 03-27-2016, 10:21 AM   #115
tj310
Good excuse to droop the nose and have to move the fenders a little closer together. ---Trevor
Old 03-27-2016, 11:10 AM   #116
Bill Diehl
Bill Diehl's Avatar
Originally Posted by tj310 View Post
good excuse to droop the nose and have to move the fenders a little closer together. ---trevor
great point...lol
Old 04-22-2016, 08:35 PM   #117
Bill Diehl
Bill Diehl's Avatar
The Diamond Boss pistons 80071 have been added to the accepted products list but they have them listed in flat top section
Diamond 80026 has been added also. those are flattops and the 071's are pop ups
Going to have to get NHRA to correct the listing as they had to with the part number of the block
Old 05-27-2016, 09:59 PM   #118
Bill Diehl
Bill Diehl's Avatar
Old 06-17-2016, 09:06 AM   #119
Bill Diehl
Bill Diehl's Avatar
What a long strange trip this has been....as I mentioned earlier I did not like the fitup between the firewall and offshore front end sheetmetal. also, I could not blast the inside of the door pillars, and the torque boxes that the frame/cage attached too showed to much "rot" in them so........new firewall, cowl/kick panels, inner rocker panels and new torque boxes fabbed up. (the inner rocker is now .100 thick as opposed to the factory .040, and the firewall is really a bargain as it has the upper torque box/plate already attached)
Old 06-17-2016, 09:13 AM   #120
Bill Diehl
Bill Diehl's Avatar
By the time I repaired the damage to the bottom of the original firewall, filled all the holes, got the other parts to fit...I was hours and dollars ahead with the new piece
