Old 04-29-2016, 08:03 PM   #21
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: Fairmont U/S Build AKA Craigslist Racer
Very cool project! My late brother had a 2 door Fairmont, was one of my favorite body styles of the time. Good luck with this!
Lane Weber
Old 04-30-2016, 07:27 AM   #22
Billy Nees
Liked 7,762 Times in 1,741 Posts
Originally Posted by Shadylane View Post
I decided since I'm running in a slow class I would remove the halo and the 'A' pillar bars.
Once I installed the swing out bar I mocked up the JAZ plastic seats.
I wouldn't do that until you speak to a Tech man! I think that you'll find that if you have a bar in the car, it must be legal. A cage has a 1 5/8 main hoop, a bar must have 1 3/4. And you must have a legal bar to use your Jaz seats.
Billy Nees 1188 STK, SS
Old 04-30-2016, 09:50 AM   #23
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I spoke with a Division 5 Tech man and I was told a Non-Certified roll bar was ok, didn't ask about the seats to be honest with you.
I removed parts of the cage/roll bar that don't affect the integrity of the rest of the roll bar, in my estimation. The cage/roll bar is 1 3/4. Hey I'm no expert on any of this but I tried to do my homework before removing it. I appreciate the feedback and will check further with the Tech people.
I'm hoping that it's not one of those deals where you ask 4 people and get 4 different answers.
Worst comes to worst I'll get it certified, if it won't certify I'll remove it and install some less safe OEM seats and the 30 pound back seat.
Thanks, Kelly
Name:	Roll bar 1.jpg
ID:	33882   Click image for larger version
Name:	Roll bar 2.jpg
Shadylane is online now   Reply With Quote
Old 04-30-2016, 10:16 AM   #24
Billy Nees
The bar doesn't need to be certified but it would still have to be legal. If the main hoop is 1 3/4 then you should be OK.
Old 05-05-2016, 10:33 AM   #25
Shadylane
Shadylane's Avatar
Ordered a Moser spool and axle kit for the 8.8. Got a 31 spline which they said should be plenty strong enough for my build. I had previously sent my axle housing to a local rock crawling shop to have the tubes and brackets welded in a straitening jig. With the housing back in the car I cut the ends of the tubes so it would accommodate the C-Clip eliminator. Installed the axles and spool without a R&P until we get the engine dyno’ed. Need to make a decision on tire size and gear ratio down the road. The down side of 8.8 axles is the lack of R&P choices. Based on talking with a few folks I’ll probably be in the area of a 29.5 tire and a 4:88 gear but that is just a guess as that may be a little too much tire. Transmission has a 3:19 low gear.
Bought a pair of used Hotchkiss adjustable upper control arms, the lowers were already on the car when I bought it. Another bonus.
The axle housing didn't have any brakes when I got the car so I went shopping on CL and found some 11 inch Rangers drum brakes which are more than adequate. Added new shoes and hardware. Been along time since I built drum brakes, had to dig out my old tools. When I win the lottery I'll buy some light weight brake components front and rear.
Received the trans back from Jerico last week. They changed the input shaft and bearing retainer to fit my FFFord. The Long ratchet shifter is a thing of beauty. Everytime I get a new part it motivates me even more to get moving on it.
Mounted the fuel cell along with an electric fuel pump. My welding on the fuel cell tabs is kind of crappy, I'll cover with paint.
Bought a used Mallory 140 from a friend. Kind of overkill for this application but it was cheap. I'll kit it and try it. I also have a used Red and Blue Holley pump as back ups.
ID:	33919   Click image for larger version
ID:	33920   Click image for larger version
ID:	33922   Click image for larger version
Name:	Fuel Cell 1.jpg
ID:	33923   Click image for larger version
Name:	Fuel Cell 2.jpg
Old 05-05-2016, 11:38 AM   #26
Jim Caughlin
Liked 805 Times in 245 Posts
What Billy is saying is correct, regardless of whether the rules require a roll bar or not, if it is in the car, it has to be legal. Kind of a funny rule but that's the way it is.
Jim Caughlin is offline   Reply With Quote
Old 05-05-2016, 01:34 PM   #27
Shadylane
Shadylane's Avatar
It is 1 3/4 mild steel. Should be legal...as per Billy anyway. The closest NHRA inspector is 7 hours away.
Thanks, Kelly
Old 05-05-2016, 06:15 PM   #28
BLIND MULE
BLIND MULE's Avatar
Cool build got a Box top Fairmont myself with a 6 lunger. A 29.5 tire is gonna take alot of trimming to fit those fenders are not real big! Good luck keep us posted!
BLIND MULE is offline   Reply With Quote
Old 05-05-2016, 10:57 PM   #29
Shadylane
Shadylane's Avatar
When I was looking for Fairmonts, I thought I wanted a box top car. The more I looked into these cars the more I started liking the looks of the Futura's. Both cars can be made light, I like the idea of the fast back and the Futura is actually an inch shorter in height, plus the windshield is laid back a little more than a box top. Probably not important for a 95mph car.
I have my body man looking at the wheelwell situation. I have a pair of 29.5 M/T's that I can fit under the car with a 1/2 clearance which I know is not enough. I think in the end I can make them work with the proper wheel offset, maybe.
Old 05-06-2016, 07:15 AM   #30
Tony Corley
Liked 61 Times in 25 Posts
Cool build. Reading this, I have a question. Why would you want to run such a large tire on a low hp application? I am just comparing to the cars I have ran, (not stock eliminator). I have had consistent 1.29 - 1.30 60 ft times in the past on a 10.5 x 26 tire, with 600 hp and a 5 speed. I realize the 10" tire is not legal for stock, but just seems something under 9" and around 26" diameter would be more than sufficient, and free up some ET by not having to carry the extra tire down the track. I'm sure there is a reason most of the Stock Eliminator guys like the big tire, so that's why I'm asking.
Tony Corley is offline   Reply With Quote
