Old 08-08-2016, 07:32 PM   #91
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 1965 Impala BBC Stocker Update
I've got 3 2 bolt main 396 blocks out in my store room. I'll look at and write down the numbers and we'll ID what they are. You got me curious.Isn't there a grooved rear cam bearing available to enable the use of the later cam in the early block? I know that a 409 has a grooved rear journal on the camshaft itself.That must be where they got that from on the early 396.
Old 08-08-2016, 08:53 PM   #92
Greg Reimer 7376
Two of the three blocks are # 3855961. Both have fully grooved rear cam bearings.The other block is #3969854. It has also a later screw on oil filter,the other two have canister type filters.
Old 08-09-2016, 08:14 AM   #93
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: 1965 Impala BBC Stocker Update
3855961 blocks are '65-'66 396. Interestingly, some '66 427's also had this casting
number.
3969854 is a '69 396 and was also used in the '70-'72 402's.
"That'll never work....."
Old 08-09-2016, 08:19 AM   #94
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
In my records, I have recorded three 961 2-bolt blocks that sonic checked over .250" thick cylinder walls.
Old 08-09-2016, 11:44 AM   #95
Greg Reimer 7376
I remember reading about the 396 375 horse 4 bolt main block being "dual purpose,"that meant, 396 or 427. It had some massively thick walls, in one case, one was bored out to 4.3150 and used a standard 409 ring. Imagine a 440 inch 396 coming at you! The later block I have was a 70 402. It had 290 small plug heads, the flat intake, and a cast crank.
Old 08-09-2016, 12:54 PM   #96
Dwight Southerland
I don't have much good to say about the later blocks.
Old 05-13-2017, 09:46 AM   #97
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Been a long time coming, near the finish line. Over 3 years now, best I can do on a limited budget. 396 Shortblock done, finish heads. Then driveshaft has to be made.
Plan is August
Will Lamprecht
Div 1 I/SA 65 Impala 396/325
ID:	39524   Click image for larger version
Old 05-13-2017, 11:04 AM   #98
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
WOW!
The car looks AWESOME ! I love it .
Old 05-13-2017, 01:23 PM   #99
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Looks fantastic!
Dave Muller is offline   Reply With Quote
Old 05-13-2017, 09:59 PM   #100
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
That car is awesome!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
