Liked 33 Times in 15 Posts
Looking for some input. Which one, what brand, and why?
Thanks.
Joe Marcinowski 3377 STK |
Liked 1,831 Times in 415 Posts
If you JUST want either an O2 sensor OR an EGT, get the AFX O2 unit from NGK. Inexpensive, simple, accurate, and reliable. An EGT unit is hard to tune with unless you're real sharp. There's nothing WRONG with tuning by EGT, IF you have a handle on it.
Alan Roehrich 212A G/S |
No one else with an opinion? Alan, are you saying its best to have both? Looking to weld fittings in before my headers go out to get coated.
Thanks, Joe
Liked 4 Times in 2 Posts
Joe, I would go with an O2 sensor setup only. It is the only true way to see the Air/Fuel Ratio.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
#5 | |
Send your headers to NitroPlate, the best coating there is, and the only coating done by a company that not only services sportsman racers, but they ARE sportsman racers.
#6 | |
I'm not familiar with what's available on the market, but I will say that you'll want a wide band O2 and a heated one at that. You'll also want to avoid any exhaust leaks before the O2. A secure ground for the header will also be required. Too close to the engine and it'll burn up, too close to the end of the collector and it'll read O2 between pulses.
Monty,
So are you saying it's impossible your too lean? Have you made adjustments to richen it up? I am currently installing the FAST wide-band (and heated) dual O2 sensor. All I can say is it is one nice package using quality parts and wiring.
Jeff Lee 7494 D/S '70 AMX |
Is the NGK deal heated? Does the bung install in the collector?
Alan, I support sportsman racers whenever possible so Nitroplate was my choice. Thanks for the response's Joe
#10 | |
The NGK has dual heaters, and the bung installs in one of the collectors.
