Old 09-07-2016, 07:10 AM   #31
goinbroke2
Liked 401 Times in 158 Posts
Default Re: 1971 Buick 455 GS F/SA G/SA Build
Nice!
You don't scrimp on tooling do you! lol
Like they say, if you're gonna do it, do it right.
I too love following your threads.
goinbroke2 is online now   Reply With Quote
Old 09-07-2016, 08:30 AM   #32
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by goinbroke2 View Post
Nice!
I really didn't see any other way, considering how many times those heads will be on and off the bench, repeatability will be very important, I should have some as run flow numbers soon.
Old 09-07-2016, 02:59 PM   #33
goinbroke2
Can't wait, I can imagine some must be concerned with you showing "secrets" lol!
Old 09-07-2016, 09:20 PM   #34
HP HUNTER
Not sure about that. Heres the flow numbers on my stock 661 casting heads.
Intake flowed @ 28 inches 4.350 bore SF 600 bench
.200 120
.300 177
.400 207
Exhaust flowed @ 28 inches 4.350 bore SF 600 bench no pipe
.200 95
.300 124
.400 143
.460 149
As you can see I've got a real power maker here.............
Old 09-09-2016, 05:42 PM   #35
R. Thorne
Liked 101 Times in 34 Posts
Where are the flow figures for .100 lift? Are these the heads off the car that have a "normal" 3 angle valve job or untouched as produced at the factory? As my post a few years ago mentioned I improved my low lift flow substantially at the expense of a small amount of loss at .400 lift. This helped my car measurably. Since that time i have done more experimenting with valve jobs, back cuts, etc. with surprising results. The oem valve seat is 45 degrees, right? I would try a 37 degree and lots of experimenting with "different" types of valves. Oh yeah, make sure the heads are cut close to minimum cc's before anything is done (saves surprises later). Ron.
R. Thorne is offline   Reply With Quote
Old 09-09-2016, 08:45 PM   #36
HP HUNTER
Great information, thanks, I will look for your thread.
Old 09-09-2016, 10:40 PM   #37
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Yes pay attention at low and mid lifts!!!!
Old 09-09-2016, 11:29 PM   #38
kansas stocker
Liked 249 Times in 48 Posts
Maybe I'm missing something here. I thought valve seat angles had to be within 1 degree of the factory angle.
Pete
kansas stocker is offline   Reply With Quote
Old 09-10-2016, 02:11 PM   #39
R. Thorne
That 1 degree refers to the valve inclination angle (I.e. the angle of the valve stem in the guide), not the valve seat angle. Any valve job is permitted as of (I think) 2009 in stock eliminator. Ron.
Old 09-10-2016, 03:57 PM   #40
kansas stocker
Thanks. That changes my line of thinking.
Pete
