Old 12-24-2007, 12:12 AM   #1
denny harvey
Default brake problem
I put wilwood 4-wheel disc brakes,a new corvette master cyl [ non power ]and wilwood prop valve to the back brakes..all new stuff...there seems to very little line pressure when bleeding brakes..i have no pedal. do i need a different push rod,the stock drum brake rod is the one on the car..seems like a bad master cyl but it is new..any thoughts,,thanks
denny harvey is offline   Reply With Quote
Old 12-24-2007, 01:08 AM   #2
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Default Re: brake problem
Did the brakes bleed o.k? Sometimes gravity bleeding the brakes works real well. Also, make sure the pushrod is far enough into the master cylinder. Hope this helps. Good luck and Merry Christmas.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 12-24-2007, 10:33 AM   #3
Bill Grubbs
Liked 564 Times in 66 Posts
Did you Bench bleed the master cylinder? If not it will be nearly impossible to get full pedal pressure.
Bill Grubbs is online now   Reply With Quote
Old 12-24-2007, 10:58 AM   #4
denny harvey
i did bench bleed the MC,when bleeding the brakes,the fluid does not seem to come out in a fast stream..i will try to gravity bleed them today..the push rod hits the MC with the pedal about 3 inchs from the floor.car has all new brakes,lines.line-lock ,prop valve and MC,so i must not be getting all the air out or MC needs ck...also there are no leeks that i can find..thanks for input guys..back to the pole barn..man ohio is cold and windy..lol..
Old 12-24-2007, 11:02 AM   #5
Tailchaser
Make sure the linkage allows the piston in the M/C full return. The geometry on the end of the pushrod may not properly fit the cavity in the rear of the piston?.thus not allowing the piston to fully return. It also may be too long, creating the same problem. If all of this is OK, then start over with "bench" bleading the M/C and follow on with the balance of the system.
All of the caliper bleeders are at the highest point correct??..higher than the lines entering the caliper?
Chasin' my own tail for 30 years and counting....(shoulda raced oval track!)
Tailchaser is offline   Reply With Quote
Old 12-24-2007, 11:03 AM   #6
Greg Hill
Liked 279 Times in 68 Posts
Make sure the bore diameter of the master cylinder is the right size or you won't have much of a pedal. I would call Wilwood to find out for sure but I think it needs to be around 1&1/8.
Greg
Old 12-24-2007, 12:27 PM   #7
denny harvey
thanks again for your input guys,the master cyl is a manual 67-74 vette with a 1 inch bore,wilwood said this would work..when i start bleeding the brakes, i bleed the pass side rear first.i get a little pedal,but by the time i get to the other side its gone,its like starting over at each wheel???? when we pump up the brakes and open the bleeder ,the fluid has little pressure behind it.....bleeders are higher then the lines..have a good holiday guys,im done working on the car till after x-mas,maybe santa can help...denny
Old 12-24-2007, 12:33 PM   #8
SPS
Liked 3 Times in 2 Posts
Denny:
GP is correct about the master cylinder size being important. We usually use the Chrysler style master cylinder available from Wilwood for these systems. Also, Wilwood also has an in-house manufactured master made for manual disc/cisc systems that is very good but more expensive.
The geometry issues brought up are also correct.
Finally, either vacuum or low pressure bleeding the system will save a lot of aggrivation. You didn't mention, but location of the master cylinder (firewall or floor mounted) will make bleeding more or less difficult.
Barring that, you could just have a defective master cylinder.
FJ
SPS is offline   Reply With Quote
Old 12-24-2007, 02:39 PM   #9
ron mattson
Liked 69 Times in 32 Posts
i had a very similar problem on my friends firebird with the same brake setup as you have and it was a defective master cyl it seemed to be getting air bound on the return pedal travel. you could actually hear hissing coming from the master..new master solved all the trouble ..
ron mattson is offline   Reply With Quote
Old 12-24-2007, 05:40 PM   #10
Jim Blankenship
the push rod isn't hitting till 3" from floor ?
should hit with just 1/2 " down any closer it won't let mc piston to fully return
also take the prop valve out till you have brakes blead.
i put one on johns car when went aftermarket 4 wheel disk had LOTS of prob's, it in box in trailer now
car stops good no wheel lock up
it had a soft pedel with the prop valve on it
hope this helps
jim
Jim Blankenship 3086 STK
Jim Blankenship is offline   Reply With Quote
