#31 |
Liked 679 Times in 180 Posts
Engine compartment prep for paint. Tried a cleaner Cajun Brown which you cut with water. Did great. Treated rust with Ospho and then Bull Dog prep. All this is new to try so we will see. Protect the patina project.
#32 |
Engine room, tubs, front end with disc brake upgrade and overhaul done. Motor delivered to Reher. Dana rebuild next.
#33 |
Well dana still not finished but Reher motor done. Should qualify.
#34 |
Liked 404 Times in 158 Posts
793lb, 1025hp, I'd be concerned it will twist it into a pretzel! LOL!
Wow...impressive numbers to say the least. Yeah, it "should" qualify. |
#35 |
Liked 7 Times in 5 Posts
Is this going to be ran in stock or superstock? with that kind of power i'd assume the motor was built for superstock unless i'm just way out of the loop on the hp #s hemi's are making in stock these days.
#36 |
Dana installed and motor waiting on proper mounts. Wildwood brakes all the way. Running in a few days or weeks I hope.
#37 |
Test fit tight. Will have to shim K member down and big time haircut on passenger shock tower to use the Mopar covers. Factory stamped steel will fit.
#38 |
Liked 69 Times in 9 Posts
#39 |
Motor back out and heading to frame shop after this D4 open this weekend. It will take an alignment but not the motor. Driver side hit somewhere in its history. Thanks for the info.
#40 |
Liked 10,837 Times in 2,252 Posts
Don's stuff is fast.
