#31 |
Liked 2,964 Times in 713 Posts
the poll - yes.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
#32 |
So how will this reflect the other divisions ? without taking their own vote?
Last edited by Mickey Whaley; 11-23-2016 at 01:01 PM. Reason: because i wanted toooooooo |
#33 |
Liked 33 Times in 16 Posts
Thanks for explaining Peter. That is exactly the way I thought it worked and see no down side to it. Unfortunately many stories get embellished as time goes on confusing the true intent.
Rich Taylor I/SA - 321 |
#34 |
Liked 237 Times in 126 Posts
Peter: Thank you. When I get my car converted, I'm in.
Would the RTs on the scoreboard read LEFT -0.002 WINNER RIGHT -0.018 Micky: James is seeking opinions of D6 drivers affected by this. James and Jim Storms run the Stock/SuperStock Combo series out here.
#35 |
Liked 431 Times in 224 Posts
Why would there be RTs on the scoreboard in an elimination round?
S/ST 51 S/C 53 |
#36 |
Liked 10 Times in 6 Posts
For Tru-Start
since the car that breaks out the most loses,a similar rule should apply on the starting line . |
#37 | |
In eliminations , when a heads up run occurs, the computer sees a different segment (for lack of the proper term) of the program.. Index, instead of dial-ins, no breakout in effect. I assume when in that mode, it won't see T-S at all. However, in the case of different class, same exact dial in.... Let's say 1st car leaves early with a -.002, and then the 2nd car leaves 2 tenths later, obviously green, the 1st car's red light won't come on until the second car leaves the beam. Correct me if I'm wrong, Peter. Really ,this is all you need to know: The Worst Red Light Loses... Period.
#38 | |
I ran bracket at the tracks that James and Jim run the Combo. I always saw my dial change to my RT on green (or red). I think it flips back to my dial after that, but I'm generally busy with stuff at the time. CJ in the rearview and such... I don't want to get off topic, but one of the things about modern drag racing that confuses new people is a lack of winner info from the scoreboard. On a breakout it gives dials and ET, but not the math that determines how the second car to the line won. If it flashed 10.30 / 10.28 / -0.02 all the info would be up for the fans. Might help with announcer code "Stevens dead on 9 ! Johnson breaks out by a thou !" Scuse me. I'm a data junky.
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 11-23-2016 at 03:28 PM. |
#39 |
Sponsor
Liked 5 Times in 3 Posts
Dale-
The scoreboards will function exactly as they do now. The only difference is with TruSTART the appropriate win-light wouldn't be on until both drivers leave the starting line. The way it is without TruSTART (currently), the race is automatically (instantly) over when the slower car leaves with a foul start. With TruSTART, the timing system waits for the faster car to leave the starting line, and at that point it determines the winner and turns on the appropriate win-light in a red light (or double redlight) situation. Hope this helps.
Peter Biondo S/Pro 1136 SS1136 Stock 1136 Biondo Racing Products ![]() |
#40 |
Double red heads up
right -0.010 W left -0.012 L Double red handicap (current) right leaves first -0.010 L left leaves second -0.012 W Double red handicap (TruStart) right leaves first -0.010 W left leaves second -0.012 L Handicap becomes as fair as heads up.
