Old 12-05-2016, 07:51 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Lifter rule in Stock
Does that mean aftermarket roller lifters are ok as replacements?
Jeff Teuton 4022 STK
Old 12-05-2016, 07:58 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Lifter rule in Stock
Can you expand on this comment?
Old 12-05-2016, 08:09 PM   #3
Jeff Teuton
The rule change effective today takes out wording about aftermarket lifters. I will look again. More later.
Old 12-05-2016, 08:12 PM   #4
Jeff Teuton
The words 'oem type' have been eliminated from the description. See 2017 Rule Changes. Anyone know the meaning of this?
Old 12-05-2016, 09:25 PM   #5
Liked 5,125 Times in 1,953 Posts
I believe this means , at least in Chebbie Land, that you can run an early block and cross bar type lifters in place of an OEM late model set up, as long as they are hydraulics.
But, we were told , here on CR, earlier this year, that this was already legal.
It sounded bizarre to me at the time, but on the other hand, I didn't doubt it for one minute.
Now, what this means in the world of Mother Mopar, I haven't a clue.
Old 12-05-2016, 10:04 PM   #6
kansas stocker
Liked 249 Times in 48 Posts
Does this mean that solid lifters are now legal? In my mind Stock hasn't been using oem type lifters for years. Light weight ceramic lifters don't seem oem type to me.
Pete
kansas stocker is offline   Reply With Quote
Old 12-05-2016, 10:08 PM   #7
Erik Jones
Liked 47 Times in 6 Posts
The only thing that chages is a "Solid" can replace a "Hydraulic" basically nothing changed.
As per NHRA tech Dept today.
Erik Jones
Erik Jones is offline   Reply With Quote
Old 12-05-2016, 10:33 PM   #8
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
So throw away all trick hydraulic stuff and go to solid lifter cams. Will make cam checking by NHRA (and racers?) a lot easier, don't have to pull anything apart to replace the lifter for checking. Of course ya gotta buy new stuff.
Mike Moller
NHRA 203 Q-R-T/SA
Old 12-05-2016, 10:59 PM   #9
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Lifter rule in Stock
Just my take on it, but since they ramble on about hydraulic lifters, it might appear that hydraulic rollers may be used in place of hydraulic flat tappets, like Jeff originally thought. If solids were allowed, then the words like "plunger", "plugged" & "bottomed" should have been eliminated.
Solids in place of hydraulics would have been cheaper & simpler. But with rollers you have to change the cam and possibly pushrods & springs to accommodate a roller profile & lifters!
LOCOMOTION Racing
Old 12-05-2016, 11:19 PM   #10
Jeff Teuton
I agree with all that, but how many of you have ground up a good motor with flat tappet lifters and aftermarket hydraulic rollers would not do that. I don't have any issue with any of this. I have all rollers, but to guys I know and in my past, I have eaten a few good motors.
