#41 |
This new rule is smart for us Racers that have lost good motors to those JUNK Ceramic Lifters!!!! and for NHRA to check cams.
#42 |
Liked 184 Times in 113 Posts
#43 | |
Liked 254 Times in 78 Posts
By the way, since lift will be checked at zero lash but you wouldn't run a solid at zero lash, I assume you have to give up some lift if you change over.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 12-07-2016 at 11:15 PM. |
#44 | |
Somebody try and let us know ....
#45 |
Liked 91 Times in 29 Posts
Please excuse my ignorance. But does this mean we can now run a solid lifter type cam in a hydraulic cam engine. IE a 396 350hp. Or just solid lifters on the hydraulic cam.
Bruce Cameron 1969 Nova E/S 1968 Camaro SS/I |
#46 |
Liked 223 Times in 73 Posts
Since any duration is allowed I don't see why someone couldn't grind slight clearance ramps (just a couple thou) into them, but it doesn't seem worth bothering with.
#47 |
Liked 1,880 Times in 422 Posts
If that is the case, then a lot of stockers are about to gain a lot of RPM, and spend a lot of money. This could get really interesting. Or really stupid. Maybe both.
Alan Roehrich 212A G/S |
#48 |
Liked 783 Times in 195 Posts
Alan, that usually goes hand in hand. It's like the chicken and egg thing.
#49 | |
Liked 799 Times in 236 Posts
![]() You can be down around .002 (hot) with a solid lifter on a 'hydraulic' cam lobe. Basically, as close to '0' as you can without hanging the valves open. A good rule of thumb.... on a typical iron head/iron block setup, you need around .003 more lash 'cold' than what you want it at 'hot' to allow for expansion. ie: .006 cold will get you .003 hot. Iron block/alum. heads & alum. block/alum. heads expand differently than iron block/iron head, of course.
"That'll never work....." Last edited by Alan Nyhus; 12-08-2016 at 10:09 AM. |
#50 | |
Liked 210 Times in 88 Posts
Phil Vos |
