#71 |
Liked 373 Times in 129 Posts
Thanks, I have tested Aug 19. In F/SA trim I ran 11.40 with zero tuning at Pueblo Colorado 4800 feet elevation, 25.10 baro, 7240 DA, .9508 correction, running the Turbo 400 with 4.10 gears. My next change is testing different carbs, a metric trans and 4.30 gears along with a rear end redesign. I really wish I had the time to really get after this combination I think it could really run.
#72 | |
Call me..Can't find your number ..Have an unrelated question for you. 602-769-0346
#73 |
Liked 20 Times in 9 Posts
The index at Denver for F is 12:60 would have been #1 qualifier at the last national with that run.
7015 E/SA Sooner Storm |
#74 |
Liked 5 Times in 4 Posts
The F/SA index for Pueblo should be around 12.46 a run of 1.06 under at altitude is very impressive!
#75 |
#76 |
Liked 46 Times in 29 Posts
Great news
I know finding time is key Same here working on my velle and GS too. Better get outside now. |
#77 |
I don't know the index in F for Pueblo, although the NHRA correction is .9508. 11.4 X .9508 = 10.84 not earth shattering.....but I'am just getting started. Stay tuned.
#78 |
Liked 783 Times in 195 Posts
11.40 / .9508 = 11.99
#79 |
Liked 112 Times in 31 Posts
Dwight,
Hunter was taking his run back to sea level with the .9508 factor. That's what that factor does. You divided instead of multiplying. As an example, the factored Index for Pueblo, 12.46 x .9508 gives you the sea level Index of 11.85. Lots of people who aren't "altitude runners" get these factors all confused. Jerry |
#80 |
I thought the index was 11.40 and was translating to the altitude factor. If the uncorrected index is 11.85, then the altitude factor is 11.85 / .9508 = 12.46
