Old 12-09-2017, 08:49 PM   #91
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Default Re: 1971 Buick 455 GS F/SA G/SA Build
Shadylane is online now   Reply With Quote
Old 12-10-2017, 11:00 AM   #92
MR DERBY CITY
Liked 8,048 Times in 1,529 Posts
Originally Posted by Shadylane View Post
I wouldn't trust what Fast Freddie says, he gets most of his information from either Don Kennedy or Bobby D.
I hear ya Mr. Shady. Riding SHOTGUN in a race car on an old country road is a little far fetched for me too......This thread has been officially hijacked.....
Old 01-13-2018, 10:08 AM   #93
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Mark
I see your running a HEI and no spark box, and I don't see a pcv?? Have you tried other set ups?? Just curious because on my street cars both showed HP on the dyno.
The more people I meet the more I like my dog
Kevin
Old 01-14-2018, 01:25 PM   #94
HP HUNTER
Liked 373 Times in 129 Posts
Originally Posted by SSGN View Post
Mark
I ran the HEI because I had not had a chance to rewire the car yet, and the fuel system seemed more important to me with the time I had to work with. Same with the testing, time was limited. What exactly did you see with the PCV valve, if you don't mind. Trying to get everything legal for this season. My oil pressure drop situation in the lights kept me from working on the metric trans along with a gear change. I've never even tuned on the car at the track or tried my other carbs. I will say this, the 1 time I've raced the car it put me in the winners circle!
Old 01-14-2018, 04:24 PM   #95
SSGN
SSGN's Avatar
We tried a few things with the PCV, one was as stock with it in a breather and the other side vented. We vented the passenger side. We also tried 2 pcv and no vent, showed HP on the dyno but no et difference. The pcv in the end of the breather that you have worked the best as the breather acted like an oil separator. This is how I set up my street cars also.
Kevin
Old 10-09-2019, 07:57 PM   #96
HP HUNTER
After finishing the year with a best of 1.01 under the F/SA index losing some MPH since the engine was first built, I suspect the short block of being tired I plan to build a new short block and change the trans this winter. Of course I will post pictures as I go, followed with a dyno test with data, followed with a track test. I need to make a decision on the bore size and piston to wall clearance, I think I've got a handle on the bearing clearance from my previous testing. I will be nitrating the crank this time as well.
Old 10-09-2019, 10:21 PM   #97
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
What does that do to the crank?
D
Old 10-09-2019, 11:34 PM   #98
HP HUNTER
D
Surface hardens the crank.
Old 10-09-2019, 11:52 PM   #99
Still a good deal for the short block. The pistons cost more than that.
Old 10-11-2019, 02:28 PM   #100
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Who does that ?
Dave Noll, EF/S ,?/SA 6526
