Liked 237 Times in 126 Posts
SS/CS allows fiberglass lift off hoods with scoop limits of 11 inches above the hood surface. Thinking of adding a glass hood with a Thunderbolt blister to my Mustang. Any thoughts on keeping it on with as little hassle as possible in getting it off?
Asking here because more lift off and tilt up glass users in Comp.
Liked 333 Times in 180 Posts
Put tabs on all around the engine compartment and fasten hood to the tabs with spring loaded flush mount Dzus fasteners . Looks nice smooth appearance and no fumbling for or lost fasteners. Fed 387
Liked 71 Times in 38 Posts
Don’t know if this will help you, check out quiklatch.com pretty slick little deal though.
Thanks, guys. I'll check both out. The Dzus fasteners seem to have the lead price wise.
Liked 311 Times in 175 Posts
Think some fasteners are not accepted by NHRA. Wonder about two large hood pin styles, similar to the Quik- Latch style?
#6 | |
I'm thinking 8 fasteners. Three on each side and two across the front. Cost will determine the exact style. A flat hood and T Bolt blister will run me around $550.
Another option would be to use 1”x1” aluminum angle. Run it through a Shrinker / stretcher so it conforms to the fender contours. Fabricate two brackets for the front, and add fasteners of your choice.
Liked 1,589 Times in 583 Posts
Dale,
Do you have aluminum or cast iron cylinder heads? SS/CS is a cast iron cylinder head class on;y; no aluminum. |
#9 | |
The flat glass hood might hood might not work. Not easy to find and quality is suspect. Lots of good 3 1/2 inch cowels so I'll probably keep light springs and hinges with extra pins and no latch.
Liked 11 Times in 4 Posts
A lift off hood sucks in Super Stock from the standpoint of having to remove it for fuel check. You are down there by yourself, if it's windy you don't want it sitting up on the roof unattended. Mine won't sit on the roof so I have to find a spot in the grass to set it. Make the hood hinged it at all possible.
Tim Kish 3032 SS/GS |
