#21 |
Liked 7,995 Times in 1,525 Posts
James, not sure We can reason with Dan....Evidently he doesn’t understand the concept of buying the STRONGEST parts first......cause you will buy them sooner or later....
#22 |
Nailed it!!
Ed Wright 4156 SS/JA |
#23 |
Liked 2 Times in 2 Posts
My Father's advice to me was always "buy your last one first."
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
#24 |
Remember Mr. Fahey drives his race car to the track so when the 10 bolt blows up on the starting line he can just call Triple AAA to tow him home. 🤑
#25 |
Liked 55 Times in 29 Posts
There is nothing wrong with your 8.5, don't let those guys tell you wrong. They are every bit as strong as a 12 bolt. I have had mine in my stocker running low 1.40s 60 foots for 20 years and about 2500 runs and I have had to replace the ring and pinion 3 times so that is about 750 runs. Put a spool and axles in it and you will be good to go.
#26 | |
#27 |
My car weighs 3350 lbs and it has a carb.
#28 |
Liked 166 Times in 71 Posts
The statement made that the pinions are different is right, I stand corrected. The pinion shaft and bearings are actually larger in the 8.5 than the 12 bolt. Maybe gm new what they were doing when they replaced the 12 bolt with the 8.5 and placed it under millions of cars and trucks lol. Once you put spool and axles in it, they won’t know they’re not in a 12 bolt housing. Run it!
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
#29 | |
Liked 184 Times in 113 Posts
Bet they have less drag than a 12 bolt and they are on every GM truck too. As for AAA...signing up with them has helped a lot. Used them a few times. Had to have the Wagon towed home but not the race car. Mid 2016 have been towing. Last edited by Dan Fahey; 04-22-2018 at 09:02 PM. |
#30 | |
I am not under my car often...and that is a good thing! and It helps to have a Forum to share experiences! Mark you car is so slow. It’s shadow waits for you at the end of the strip ! Dan |
