Old 04-26-2018, 08:59 PM   #51
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: 12 Bolt vs 10 Bolt Rear
Why not use a '65-'70-ish Impala 12 bolt housing? The dimensions are close enough that new housing ends will get it to the same width as the later housing. Get a junkyard late model housing and use the brackets on the early housing. -Al
"That'll never work....."
Old 04-26-2018, 10:30 PM   #52
Alan , 65-70 does not have ears on the center casting. They are on the tubes and aim straight ahead. Factory panhard bar is used. Also there are no spring pads on the housing.
Better off starting with a 68-72 Chevelle unit, I would think.
Old 04-26-2018, 10:53 PM   #53
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Got it figured out.
Maryland High Performance will fix up the 10 bolt.
Also get them to add a Roll Bar.
They have the equipment and experience.
It is all good.
D
Old 04-26-2018, 11:09 PM   #54
Alan Nyhus
Yeah...forgot about the cast ears on the center section. You're right on the Chevelle unit.
