Liked 184 Times in 113 Posts
I am running into a new issue.
Currently running a 4L60E trans and Yank PT4400 Locking Converter Needs more converter but nobody makes a higher stall speed Converter. Which makes plans to move up to Stock interesting. I like the programmability of the 4L60E. So what options are out there? Also will I need have drive shaft issues? Dan |
Liked 28 Times in 9 Posts
Dan,
You have really answered your own question ; purchase a good turbo 200 and you will have any of a number of convertor shops to choose from .The reality of stock eliminator is if you don't do it right the first time you will be sorry . |
#3 | |
Liked 5,125 Times in 1,953 Posts
Do you mean lock up converter?
What do you need a lock converter for? You won't even use 4th anyway.
Most race manuals use a direct 4th. You can under drive an old Nash or maybe even G-Force, but not overdrive it.
Liked 239 Times in 114 Posts
Come on Mark , a converter clutch will certainly be more efficient in high gear , the question will be how it will effect the launch with all that extra inertia on the turbine .
Liked 3 Times in 2 Posts
When I ordered mine from ATI they suggested to lose the lockup and go with an 8" and for that exact reason with the reduced weight Charlie felt it would work better overall.
#10 | |
However, what Dan has on hand may work in Pure Stock, but it's all wrong, wrong, wrong for stock eliminator. You know that. We're not trying to re-invent the wheel here. Just run a couple of tenths under the K/SA index. That is, I think that's the plan. Going to have to agree with Brian here. Just set that o/d., lock up deal under the bench for now.
