Liked 19 Times in 9 Posts
What is legal now in Stock for lifters, and what are you Mopar guys using?
Tool steel? Coated, yes no? How about oil holes, yes no? I want something that will work with Stocker cam profile and spring pressure Thanks for the help! Tom |
Liked 346 Times in 126 Posts
watching
Liked 2,462 Times in 694 Posts
I am probably one of the few still running Smith Ceramic low travel hyds.
Getting harder to find all the time!
Liked 10,679 Times in 2,222 Posts
John how many do you want?
Liked 21 Times in 13 Posts
I just bought a set of solids from Barton. These are un-coated tool steel lifters made for him by Trend. Using them on a cast iron cam. Sorry, these are for a BB
Brian Carpenter Stock 1358 Last edited by GallopinGhost; 05-11-2018 at 07:24 AM. Reason: not enough coffee.... |
Liked 28 Times in 15 Posts
Suggest you talk to John at Bullet Cams
Big and Small Mopars have the same .904 lifter.
Larry: I will buy all I can get.......At least the few that the bottoms have not fallen out of yet or shattered: Generally destroying the engine along with the darn lifters h Yes = my kids think I am Nuts....But I use the Hyds with healthy preload and check them a LOT!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 05-12-2018 at 01:19 AM. |
Liked 44 Times in 21 Posts
I run Ferrea tool steel, in my factory solid cam engine
Steven Barnes Stock 704 N/SA |
I take it solid lifters are now legal for Stock?? You don't need to use the low movement anymore? Can you safely use tool steel lifters on cast camshaft??
Liked 464 Times in 113 Posts
Talk to PPP lifters. They have a special coating designed for running a tool steel lifter on a cast cam.
68 Chevy11 327 F/S |
