Liked 6 Times in 5 Posts
The car started last week and went to start it this week and won't fire. We've changed everything. Any clue of what it might be would really help. Thanks.
And no rpm on tac or big stuff if that helps.
Liked 1,965 Times in 595 Posts
When mine wouldn't start it was the pick up on the crank trigger also one time my car would not start the needle and seat was stuck and no gas was getting in the carb. Had fuel pressure but no gas in the bowl. Check that
Mike Pearson 2485 SS Last edited by Mike Pearson; 05-23-2018 at 07:25 AM. |
Mike, we changed that. No luck
Liked 80 Times in 28 Posts
neutral safety wire ?
Liked 101 Times in 52 Posts
Liked 56 Times in 27 Posts
Check for spark & re-check all your Ground wires & connections !!!! Loose wires ?
Dave Ribeiro 1033 STK |
We've checked that to
Liked 778 Times in 142 Posts
No rpm pulses when cranking suggests trigger pickup issues. 60-2 tooth wheel with Hall effect? They are very sensitive to gap. May have been right on the edge all along and now just out of range.
Kevin. We have checked that 3 times. No luck
