#91 |
The motor mount deal reared its ugly head again. To my understanding the BB mounts roll the motor 1/2' to the passenger side. With the SB mounts I loose the clearance on the header, Its not touching but its as close as it gets, I guess a small dent is in order. I also had to change the Z bar out for the SB one.
[IMG] Nice job on your project, can I ask why you had to change ZB to the Small Block one?
Keith A/S 2990/Terri A/SA 2991 "Imagine what you'd attempt, if you knew you could not fail!" |
#92 |
Liked 319 Times in 82 Posts
Nice job on your project, can I ask why you had to change ZB to the Small Block one?[/QUOTE]
Thanks! I used SB frame and motor mounts for the oil pan to clear the drag link. From what I have read the BB mounts roll the motor 1/2" to the passenger side. The BB z bar is 1/2" longer than the SB one to acount for that. I was looking at shimming out the frame mount for the z bar but with the SB one it fits like a glove. This is the same reason I'm tight on the header. Stahl recommended the BB mounts with these headers. |
#93 |
Liked 799 Times in 236 Posts
Honestly, if it was mine I'd face the mounting bosses off about .125 to move the box laterally. The rag joint should accomodate this. The column could be loosened up and lined up accordingly, as well. Then, no header gasket...just a thin bead of sealer like Valco Aluminized silicone.
For what it's worth. -Al
"That'll never work....." |
#94 |
Liked 310 Times in 174 Posts
Do a mock up with a Vega Box. Note: You may need a special Pitman arm if you go that route.
#95 |
Liked 162 Times in 45 Posts
Calvin Elston makes the nearest smallest motor mounts for your car. You can put the motor where you need it to be. Also save a lot of time changing motors. The work like a motor plate. Completely NHRA legal for stock eleminator.
#96 | |
Todd Greene |
#97 | |
#98 |
#99 |
And a very cost effective idea too.
Todd Greene |
#100 |
Liked 10,736 Times in 2,234 Posts
Hope to see you and the car in the lanes soon. Some nice work! Good Luck.
