Liked 53 Times in 20 Posts
When I started racing in the mid 60s it was only class I ran mostly A/S and I ran all the other A/S cars and every other class ran each other the same then at the end of the day the winner of each class ran each other on a handicap system for overall eliminator. Why did it ever change that is the way it should still be but it is not. I know people will say you can't get a big enough car count today because the slower cars wont come. Why is it different today, back then if you had a slower car you worked on it to make it faster for next week. The payout was 25 bucks for a class win and 100 for overall eliminator. Why can't we go back to what worked there was no AFHS you tried to go as fast as you could and every week you tried to do better. Am I just dreaming of the good old days.
Liked 237 Times in 126 Posts
The entire sport has become too complicated for that to happen again. In the 60's all the stockers were street driven or bumper towed and the rules made it less expensive to race. SS cars were suped up factory cars and stuff like 4-links were no where to be seen. Transmissions were street issue and tires had to have tread. The best shot at more heads up class racing would be to re designate Sportsman as weight to HP unmodified engines. Let people run pure stockers or swap stock engines in same badge bodies. Allow fiberglass but require a weight sticker. Weight to CID is best but superchargers and EFI mess that up due to the different HP output.
#3 | |
Running off records was too hard for too many, evidently.
Ed Wright 4156 SS/JA |
#4 | |
Liked 136 Times in 49 Posts
Liked 779 Times in 209 Posts
One way of having more heads up runs you would have to go to 1lb. weight breaks instead of 1/2lb. breaks.
"Pistol" Pete Dutko |
#6 | |
I have a 1966 rule book I found in a model building forum. There were 27 classes (A - O) in Stock/Super Stock with stick and auto totaled. Super Stock was one class, S/S and S/SA. FX had three classes. Most of what we know as SS cars would have been either in FX or classed as gassers/altereds. FX could swap engines like GT but Stock and Super were original motor only. Cams were allowed in S/S S/SA and A/S A/SA only. Quote that applied to Stock and Super Stock. "Engine equipment other than regularly produced for assembly line production by the manufacturer is not permitted except as noted in these class rules." You could change pistons as long as the CR stayed the same. How many grand would that slice out of the cost of class racing????? I ask because I'm math challenged... The entire rule book was 28 pages long and the NHRA was run by 10 people. Membership was $8 per year. Base 289 2BBL Mustang $6000 off the lot.
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 01-15-2019 at 11:55 AM. |
#8 | |
Liked 135 Times in 74 Posts
For example if a record is set in A/S at dutch classic, usually mineshaft, and there is no one racing B/S at this event, and B/S is set at indy in the heat of the summer, the next year at U S NAtionals, B/S will have a Big advantage over A/S if they race off records. To make it work you have to altitude correct records |
If the tracks were at over an 1000' elevation, we ran off of altitude corrected records. Around here (Div 4 seldom has "good air") I won points races running a tenth off my record. The fast car there that day. Didn't see a lot of brake lights before the finish line back then. :-)
Kinda comical at national events around here, and the World Finals when held here, to see national record holders that had set their records at Atco, NJ or Fremont, CA show up here, and could not run fast enough to qualify. They just thought they were real fast because of the tracks back home. And, people not bright enough to not set records in mineshaft conditions made it tough for others running their class. We didn't all have these weather stations & Crew Chief Pro software back then. All we knew was "Man, it's slow here!" :-)
Ed Wright 4156 SS/JA Last edited by Ed Wright; 01-15-2019 at 01:13 PM. |
Liked 920 Times in 259 Posts
Look around. Nothing is as it was in the "good ol' days" and never will be. At least we can still remember it, mostly, and wax nostalgic.
