Old 01-19-2019, 10:37 AM   #871
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
Al, I have a buddy here that has good things to say about Line2line, we have discussed this as an option. Someone here that has a supercharged hemi promod said his piston life doubled with this coating. This will be call #1 on monday, thank you.
Todd, check your pm's. -Al
"That'll never work....."
Old 01-19-2019, 02:59 PM   #872
Kirk Morgan
Liked 80 Times in 44 Posts
If your trying to use what you have knurl the pistons.
Kirk Morgan is offline   Reply With Quote
Old 01-20-2019, 09:43 AM   #873
HP HUNTER
Liked 372 Times in 129 Posts
Can you knurl pistons that much? When you have rust pits as the OP has, you can't go in there with the CV and hone them out, unless you go .070.
Old 01-20-2019, 09:51 AM   #874
Billy Nees
Liked 7,761 Times in 1,741 Posts
Todd, if your pistons mic up, don't knurl them. I'm sure that you can find a decent block to quickly put around that rotating assy.. There are still plenty of good 4" bore blocks around.
Billy Nees 1188 STK, SS
Old 01-20-2019, 11:11 AM   #875
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Don't knurl pistons......heavy coat can gain you .003 in diameter. Just make sure skirts are not collapsed.
Old 01-20-2019, 01:31 PM   #876
Nmbr1GMfan
I'm not going to knurl the pistons... we have technologically moved way beyond that. First off thanks everyone for all the help. A few phone calls yesterday, Al Nyhus gave me some great insight on L2L coatings that he has very real world experience close to my situation with great results. I called L2L yesterday but hung up after two rings after realizing their web info said M-F, about an hour later they called me and said they had missed a call from my number and would be glad to give me some info. After about a 30 minute conversation I had come to the conclusion that this would no doubt be a great option and be the quickest way to get us going. Thank you Al and Brian@ L2L. Second call was from Jim Marshall, Jim said depending on the exact piston I have he may have a set that would work for us, I'll check Monday and go from there, thanks to Jim for the continued help. So with that being said, once I get a little info Monday I think we may be on the way with a real solution to begin moving forward.
Todd Greene
Old 01-21-2019, 04:37 PM   #877
Nmbr1GMfan
Pistons are on their way to Brian at Line2Line. Called Gregg Luneack today about rings, he needs some info that I'll get tomorrow so they can get ordered. Piston pins are a little ugly so +001 pins are ordered. New rockers are ordered. Bores are straight just under 4.070, we'll final finish the hone when I know more about the rings.
Todd Greene
Old 01-21-2019, 04:57 PM   #878
Nmbr1GMfan
I may have forgotten to mention it but the new K&P filter came...
Todd Greene
Old 01-25-2019, 03:11 PM   #879
S/ST J718
WOW..... Amazing same size fitter element we have on Harley engines that range from 80 cubes to 117 cubes......
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
Old 01-29-2019, 11:34 PM   #880
Nmbr1GMfan
Mid week update... crank will be done this week, bearings are ordered, rings will probably be here early next week, pistons are on their way back, new pins are here.
Todd Greene
