Old 02-13-2019, 12:33 AM   #11
Mbodnar
Mbodnar's Avatar
Liked 8 Times in 6 Posts
Default Re: Evans Coolant
Originally Posted by SG RACER View Post
Thanks for the info. Once car gets hot have a hard time getting the car to cool down after a run in short amount of time. It gains temp quick after making the first hit of the day.
Evans will not make your vehicle run cooler, its just a legal fluid that won't freeze, rust and has a higher boiling point.
Class Racer Magazine Writer
Super Comp A197
Mbodnar is offline   Reply With Quote
Old 02-13-2019, 02:14 AM   #12
SG RACER
Car has a Afco scirocco radiator/fan/shroud and a Meziere 55 gpm pump with 16 an hoses top and bottom. Had a 12 an hose from top of intake to top radiator and switched to 16 an and it did help with cooling the motor down a little faster but still can’t cool down very quick.
SG RACER is offline   Reply With Quote
Old 02-13-2019, 08:23 AM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
1. that water pump needs a radiator with the same size inlet and outlet as on the pump.
2. what temp are you staging at?
Old 02-13-2019, 10:06 AM   #14
Steve Stasko
Liked 274 Times in 143 Posts
The larger AN helped because the pump was able to push more coolant through the radiator. The more coolant you can push through the radiator, the faster it will cool. At the same time though, you're trying to push 55 gallons of fluid per minute through a 1" (16 AN) hole. You really need to open up the inlet/outlet to get more coolant through the system. You could put a stock water pump on, and see no change in temperature, with the restriction being caused by the 16 AN inlet/outlet...
I understand you may be space confined with your application, but I would see if I can get something larger than a 2'x1' Scirocco rad. I honestly didn't even know those things were still being used outside of dragsters and altereds.
Old 02-13-2019, 09:49 PM   #15
SG RACER
I try to roll into the water at 110 and leave the line at 140 and go through the lights at 170 +. Car does have double pass radiator. Talked to Meziere they told me to use the 12 an on top and 16 an to slow the water flow down. Both Afco and Meziere said this should have no problem cooling off after a pass.
Old 02-13-2019, 09:54 PM   #16
1320racer
1320racer's Avatar
what's in the radiator now?
Old 02-13-2019, 10:01 PM   #17
SG RACER
Water and Purple ice
Old 02-13-2019, 10:05 PM   #18
1320racer
1320racer's Avatar
get the purple ice out
Old 02-13-2019, 10:07 PM   #19
SG RACER
Why?
Old 02-14-2019, 07:34 AM   #20
1320racer
1320racer's Avatar
it's a coolant, coolants don't cool and it also has a reputation for eroding aluminum.
