#991 |
Yes sir, got some on the way as we type.
Todd Greene |
#992 |
Liked 5,125 Times in 1,953 Posts
I'm sure it's here somewhere, but why the new cam? What's different about it?
#993 |
Mark, the cam is the same, I did send it out and had it profiled so I have a cam card. The lifters are being swapped out, that's why I'm breaking it in.
Todd Greene |
#994 |
Just a little info for everyone, seems a lot of people are running the PAC 1409X springs on their stockers. I had some issues finding an ID locator spring cup that would work because well, they didn't make one. Ended up having to make some for this particular head. When I questioned PAC, although they didn't recommend it, they said most were more than likely just throwing the 1409Xs in the head without a cup. Now fast forward to having my break in rockers not work, I needed a solution for a light spring for break-in. I ran across a direct drop in that works perfectly with the cup and the retainer from the 1409X... they're factory beehive Dodge Viper springs that will show about 85lbs at 1.800 (closed). Hope this helps someone in the future.
Todd Greene |
#995 |
Pretty much done with the engine, me and Autumn went down and swapped springs today after she got out of school. We'll throw some oil in it tomorrow, start breaking in the cam and heat cycling the piston coating. I have to pick up some longer valve cover bolts too.
Todd Greene |
#996 |
Liked 355 Times in 136 Posts
Spacers look great! Nice that you and Autumn are able to run those chebby valve covers.
#997 |
Autumn is proud of those valve covers, she bought them with her own $$$.
Todd Greene |
#998 | |
You probably would have been alright without the extra steps. I won't even tell anyone what we did on a recent one. I don't want to give anyone any ideas. It broke in and runs fine though. A good moly lube and some Lucas zinc additive helps a bunch, I think.
#999 | |
Liked 26 Times in 11 Posts
See you at the races, Wayne Kerr |
#1000 |
I haven't, just seems these lobes might be hard to control with little spring pressure.
Todd Greene |
