Old 03-20-2019, 10:07 AM   #1031
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
I can't remember the clearance, maybe .0023. Dial bore and mic. This isn't a clearance issue, it's an oiling issue.
Ok what oil pump,clearance between oil pickup and pan? Oil restrictors,drain back holes?How much oil?
Old 03-20-2019, 10:34 AM   #1032
Nmbr1GMfan
Std volume, 1/2+, no restrictors, drain backs clear and opened up, 6 qts (over full).
Todd Greene
Old 03-20-2019, 10:56 AM   #1033
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
It was definitely from a lack of oil issue....
Bad pump, restriction of oil flow or pressure/volume
Small blocks are pretty trouble free generally in this area.
A small Plug down inside a passage under the rear cap....front and rear cam plugs.....cam bearings...…things to check...
If the crank was ground it is a MUST to run a brush thru all the oil holes....and wash it real good...….
Seen guys take a fresh ground crank out of the box and just install it.
Over full oil pan could have caused the oil to aerate from windage.....but that's a stretch.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-20-2019, 11:07 AM   #1034
Nmbr1GMfan
I believe it's a volume issue (I'll know more today when I look at some measurements) All the plugs are in and the cam bearings look good, only the rods (last to oil). Crank was run through the washer and brushed. Is there a way to get oil pressure closer to the crank and not in the galleys?
Todd Greene
Old 03-20-2019, 12:25 PM   #1035
Glenn Briglio
Not really a stretch when putting 1 quart over.What size oil filter? Pickup to pan should be a max of 3/8".
Old 03-20-2019, 12:30 PM   #1036
Terry Bride
[QUOTE=Rich Biebel;585328]It was definitely from a lack of oil issue....
/QUOTE]
After looking at the state of the mains on your original dis-assembly, this is where I would look first.
If this was missed on the original build, it has been circulating unfiltered oil all along.
How much oil pressure did you have on the dyno prior to the bearing failure?
Terry Bride is offline   Reply With Quote
Old 03-20-2019, 12:34 PM   #1037
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Yup, I noticed that "1/2 +" as quoted and like the 3/8" measurement personally. Really feel for you and Autumn, such rotten luck on a very straightforward engine build. SBC oiling at this approximate power level should be bulletproof as it comes from GM.
Old 03-20-2019, 12:47 PM   #1038
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Oil viscosity (also known as 'weight') and temperature play a significant role in engine bearing clearances and what the given oil pumps performance ( flow rates) will produce.
Please keep us informed on your investigations.
Old 03-20-2019, 12:52 PM   #1039
Nmbr1GMfan
1 qt filter, Oil was a little high, just under the windage tray.
Todd Greene
Old 03-20-2019, 12:54 PM   #1040
Nmbr1GMfan
[QUOTE=Terry Bride;585340]
/QUOTE]
50-55
Todd Greene
