Old 03-22-2019, 12:47 PM   #1071
MR DERBY CITY
Liked 7,953 Times in 1,524 Posts
Default Re: H-I-J '76 Nova re-fit.
Guys, it’s common for racers with SBC combos in stock Eliminator to run more than 5 quarts of oil....this is how they combat the AHFS....
Old 03-22-2019, 12:49 PM   #1072
Nmbr1GMfan
Originally Posted by Glenn Briglio View Post
You said there was a lot of oil coming up thru solid lifters. How did you verify that? If so you might need restricted oil hole pushrods. Or oil restrictors in block
The old lifters put very little oil to the rocker, these are like a flood at the rocker. I could tell a huge difference when just pre lubing. I've been told restrictors drilled to .0120 for EDM lifters and it will be easy to swap them if necessary without opening the engine up.
Todd Greene
Old 03-22-2019, 01:06 PM   #1073
Nmbr1GMfan
And... it's a 6qt pan with a 1qt filter with 6qts total, not really so much over filled. I do however think optimum is lower than 6.
For camparison, here is the pan with just under 4qts and the pan with 5 1/2qts. How much HP is here, I haven't got to experiment with, but I will.
Todd Greene
Old 03-22-2019, 02:24 PM   #1074
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I had a '69 Nova back in the 90's......G/SA and H/SA
It was a dog.....I bought it turnkey and it was used up...Venolia pistons and way to loose.....
I redid the engine as cheaply as possible with TRW pistons......all old tech stuff , fat rings, old Lunati cam and lifters, STOCK heads and intake. Notice the caps, LOL.....It ran 11.80's at G weight….with a Powerglide…..
One day just for kicks I drained a quart of oil and it made ZERO difference. It had a stock pan on it and I think I put 5-6 in it total.
Cast crank, stock rods......gm block... +.040
That engine just could not pull much past 6800 with that cam and lifters and springs.....
Since you want to keep those EDM'ed lifters and can't fix the lifter bores, you have to try the restrictors...….I used them many times and drilled them out.
The higher oil level in the second picture might have been getting whipped up some by the crank.....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 03-22-2019, 03:16 PM   #1075
Rick Schilling
Liked 14 Times in 10 Posts
I am by no means an expert engine builder but I would also be very concerned about the uneven wear pattern on the bearings. I've seen rebuilds that have had a considerable amount of taper in bearing clearance on all of the rods, which could seemingly only be caused by taper in the crank journal, the rod bore, or the bearings themselves. Just a thought.
Rick Schilling is offline   Reply With Quote
Old 03-22-2019, 06:48 PM   #1076
HP HUNTER
Liked 372 Times in 129 Posts
What would Tony Fiel do?
Old 03-22-2019, 08:20 PM   #1077
Rich Biebel
Tony Feil ?
A Really lame post right there no matter what your point is.
Rich Biebel
S/C 1479
Stock 147R
Old 03-22-2019, 09:08 PM   #1078
Tony Feil ?
I suppose that depends on your interpretation , but come to think about it, Tony would restrict the oil to the top end of all my solid lifter SS SBC's , 40 years ago.You DO remember that?
In my opinion, here we have we have a stack up of problems causing oil starvation.
Solid lifters with lash, EDM hole in lifter, groove(?) cut down to the cam, middle valley holes raised, (not a bad thing in itself) pick up 1/2 " off the floor of pan, stationary engine on dyno, (again, not a problem in itself) , but it is what it is now, as the pictures illustrate.
Old 03-22-2019, 09:25 PM   #1079
Rich Biebel
Well since I worked at Tony’s going back to 1966 and for Tony’s former first employee for over 10 years ....
Yes back then it was common practice to tap the 2 side passages under the rear cam bearing and install drilled Allen set screws. It was the preferred method over the screw in the back types.
But we already discussed restricting the oil passages and WTH does Tony have to do with any of this. Nothing and he’s gone so let him RIP
My only point in posting occasionally is maybe to offer some help or make a suggestion from what I see and read.
Rich Biebel
S/C 1479
Stock 147R
Old 03-22-2019, 10:04 PM   #1080
Nmbr1GMfan
The lifter bore cam oiling modification I am not clear on what was done. If it is possible to undo that ? If a slot or channel was machined I assume it could not be returned to stock. If a hole was drilled you might be able to plug those holes. The direct feed lifters bleed off a lot by themselves right on the cam.
Took a picture while I was there today.
Todd Greene
