Old 03-23-2019, 06:33 PM   #1091
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Jim Hanig View Post
Just a though ,make sure the screw in plugs in the front are not in to deep, Center one .
Yes, they were checked carefully.
Todd Greene
Old 03-23-2019, 06:42 PM   #1092
Nmbr1GMfan
It was nice to get away from the engine for a day (we'll be back to that tomorrow) Autumn and I went down to work on the car today. Although I may get hamered here for this kind of work, we had a nice afternoon cleaning the underneath/underhood of the car.
Todd Greene
Old 03-23-2019, 07:08 PM   #1093
Dissident
Liked 73 Times in 36 Posts
Todd,
Someone mentioned that the thing would live.....but recent history doesn't support that notion. If you were running on the dyno at 600rpm/sec and going from 4000 to 7500, that only takes 5.833 seconds at 300rpm/sec twice that time. SO, if you total the pulls in time, that is not a livable package.Normal lifter to bore clearances is where a normal leak occurs. If it is sloppy, as an example 0.002", that leakage is approx equal to a jet of about 0.058" diameter oer lifter bore/lifter and that is additional to the groove that somebody increased the leakage path with. That flow number would scare most folks.Not a good package at all. IF you had the block reamed and honed for larger lifters, it would probably take a 0.904" lifter to clean up the groove leak. Yeah, not legal, but might save the block but would cost for another set of lifters and the cost of increasing the lifter bores. BTW - all that leakage and resultant deluge drops right down on the rotating assembly and the windage losses go up exponentially with RPM.
The lifter/bore flow above is in excess of 8gpm!!!
Best of luck to you and Autumn. Hope you get to race soon.
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 03-23-2019, 07:20 PM   #1094
Nmbr1GMfan
Originally Posted by Dissident View Post
Todd,
Regards,
HB2
Dissident
In my mind, the only difference between then and now, is lifters. These lifters have two real differences from the old lifters, the oil flowing from the edm hole and the extra oil pumped to the top (which I believe is more than the edm hole flow). So if I restrict the oil so less goes to the top and I plug the edm holes (or get non edm lifters) that should get me back to square one. I could even add a hv pump for insurance. Thanks for the replies.
Todd Greene
Old 03-23-2019, 07:40 PM   #1095
HP HUNTER
Liked 372 Times in 129 Posts
Do you have Trend lifters in this engine?
Old 03-23-2019, 11:46 PM   #1096
killintime6968
Liked 91 Times in 29 Posts
If you can get or borrow a set of clear plexiglass rocker covers to use when on the dyno it might also give you a visual perspective on whats going on.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 03-23-2019, 11:47 PM   #1097
Nmbr1GMfan
They're Bullets edm lifters. I don't know who manufactures them for Bullet.
Todd Greene
Old 03-24-2019, 02:04 AM   #1098
Kenny McCoy
Kenny McCoy's Avatar
Liked 5 Times in 3 Posts
Need way less oil up top then you think you do..
Kenny McCoy is offline   Reply With Quote
Old 03-24-2019, 08:20 AM   #1099
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Especially with roller rocker arms.
Old 03-24-2019, 09:10 AM   #1100
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Might want to start with oil restrictors with .060 hole in them on engine stand and prime engine to see results up top.You can always make the hole bigger.
