Old 04-06-2019, 05:42 PM   #1111
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Decided to get the tires mounted earlier this week. Cut the shock mount and got a thin nut for clearance with the rim, hard to see but now we have clearance. Rears are on for good, front is on to check backspace and they're way better than the old ones (I'll add both pics to see the difference in backspace). Now we have to swap the new front studs in and bolt the fronts on for good.
Before: too far out.
After: nicely tucked.
Todd Greene
Old 04-06-2019, 10:38 PM   #1112
Dave Gantz
Liked 251 Times in 125 Posts
How's the motor coming?
BTW, isn't it amazing that, with all the technology in this world, we have to buy tires that seem to have their lettering painted by a 2nd grade class? (Apologies to 2nd grade classes.)
Old 04-06-2019, 10:47 PM   #1113
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Todd,
Did I see a bleeder screw on the bottom of the caliper?
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 04-06-2019, 11:13 PM   #1114
Nmbr1GMfan
Engine is coming along with the obvious BS setbacks... Like the bearings that come loose in a box totally destroyed. Funny I didn't even notice the lettering lol.
Todd Greene
Old 04-06-2019, 11:15 PM   #1115
Nmbr1GMfan
Originally Posted by Keith Bennett View Post
Todd,
Yes Keith, for whatever reason, they have bleeders top and bottom.
Todd Greene
Old 04-07-2019, 08:24 PM   #1116
Keith Bennett
I guess so you can run them either side.
I never have had that nice of stuff.
You two are building a top notch ride...
Old 04-08-2019, 10:12 AM   #1117
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I have NEVER seen bearings packaged and shippped like that...
Are you buying your parts on flea-bay??
Whose bearings are they??
Bob Mulry 7516 STK
A & M Motorsports
Old 04-08-2019, 12:58 PM   #1118
Nmbr1GMfan
Never seen them like this either. Came from https://www.atechmotorsports.com/
Todd Greene
Old 04-08-2019, 03:19 PM   #1119
FED 387
Liked 333 Times in 180 Posts
Looks like A-Tech is a subsidiary of SUMMIT
Old 04-08-2019, 10:19 PM   #1120
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The "About" tab of that distributor says it's a global wholesale distributor of parts. If you bought the house brand you were putting genuine Chinese parts in your build. I do Ford, but I'll guess those are main bearings. I can't seem to be able to spend over $100 for King or Clevite bearings, so what powered your decision here? Bearings and rings are ultra stressed stuff and need to be top shelf.
Dale Shearon
68 Mustang 6394
